AC blows cold out one vent but not other
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kharth, Apr 14, 2025.
  1. Apr 14, 2025 at 2:59 PM
    Kharth
    Kharth [OP] Well-Known Member
    Tim
    West Texas
    '13 Tacoma 135k miles
    Leer Cap, black barrel tire valve caps, Steelers sticker, Air Freshener
    I was driving to work here in Texas yesterday and it was 99F and I got cold AC out the far left vent but not the middle 2. They all blew the same force so I know it isn't plugged up and the blower works. Does the AC cool all the air at once or is it like separate for each vent? Do you think it was just because it sat in the sun all day and it was like 300F inside the car and the vents and stuff were so hot it warmed the air and the outside one just cooled down fastest?
  2. Apr 14, 2025 at 4:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It may be low on refrigerant, check and see if the suction line is cold with the engine running & A/C on high.
    If it's not cold or is barely cool you have a refrigerant issue (low on refrigerant or other refrigerant related issue), if it's nice and cold you may have a blend door issue (actuator not moving to full cold, broken door, etc).
  3. Apr 14, 2025 at 4:43 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    +1 on a symptom of a low refrigerant charge impacting the evaporator, especially if it partially or completely goes away on a colder day.
  4. Apr 14, 2025 at 6:05 PM
    Kharth
    Tim
    West Texas
    i just recharged it about 2 weeks ago, there is prolly a leak somewhere
  5. Apr 15, 2025 at 5:45 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    I had the same issue when I first bought my truck. Topped up the refrigerant with one of these cans and it worked completely fine after.
  6. Apr 15, 2025 at 5:53 AM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    Yeah sounds like it. Def a symptom of low refrigerant. I would check the condenser first. The UV dye is likely the best option.
  7. Apr 15, 2025 at 8:02 AM
    Williston
    Did it take a while for the issue to return after the re-charge? If so, it's likely a slow leak somewhere. I had this happen to me one time and a re-charge fixed it. It stayed cold and the issue never returned before I eventually traded the car some time after.
    photodoc likes this.
  8. Apr 15, 2025 at 4:32 PM
    Kharth
    Tim
    West Texas
    I had the ac motor and stuff replaced in September and it lasted until it was cold then I didn't use it until last 2 or 3 weeks. I had a recharge can so I threw it on there and it was low so I filled it back up about 2 week ago. I can check the level again if its low i prolly got a leak or maybe it needs a top off idk. Gonna get that dyed stuff see if i can see it come out or whatever
  9. Apr 15, 2025 at 4:54 PM
    Williston
    I recharged it myself as well. It was just slightly low and didn't take much to bring it to full charge per the gauge. It never happened again in the time I had it for another 40-50 thousand miles so I just chalked it up to a gradual natural aging loss over-time on a 20+ year-old car.
    I have heard, but cannot verify, that overcharging can cause the same or similar problems. YMMV
  10. Apr 16, 2025 at 6:33 PM
    Kharth
    Tim
    West Texas
    Yeah that line isn't getting cold. Idk i let it run a minute or two. Gonna check the charge tomorrow
