AC Blows Hot When on Cold Setting and Cold When On Hot Setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ibuprofelin, Aug 25, 2013.
  1. Aug 25, 2013 at 5:51 PM
    ibuprofelin
    ibuprofelin [OP] Well-Known Member
    Hey everyone, have a bit of a predicament haha. So I have a 2008 access cab and I went to put a 2012 climate control panel in it. I had the black A33 harness already in the 2012 panel with wires attached, so all I did was cut off my old harness and solder the wires onto the new one. Everything works great, but, the AC is reversed. It blows hot when the dial is on cold and vice versa.
    Following this thread
    http://www.tacomaworld.com/forum/2nd...er-tacoma.html
    According to the wiring diagram, the grey wire (AC) should be in socket 16 on the new harness. However, on the 2012 harness that I have in my hands, it is in socket 13. Would moving the grey wire into socket 16 make this work? I'm really not quite sure if this would fix it, but like I said everything else works perfectly. Also, where in the world would I get a pin connector to place in the harness? Tried looking online but no dice. Is there an easy fix for doing this?
    Thanks a bunch!
    Cross posted in the Technical Chat forum, in case.
  2. Aug 27, 2013 at 4:59 PM
    ibuprofelin
    If anyone has some tips for taking out individual pins (they're super tiny) that would be wonderful.
    I don't understand exactly why moving the AC wire (grey wire) from pin 13 to 16 on the 2012 harness may fix this, but I'm thinking it's my best shot at this point. Anyone have any opinions?
  3. Sep 3, 2013 at 4:10 AM
    ibuprofelin
    Just an update, I moved the grey AC wire to pin 16 and that didn't fix it. Perhaps I have two wires crossed? I'm sure they're all matched up, but does anyone have an idea of what two wires would cause the AC to be reversed? I'm not entirely sure what all the acronyms means on the diagram.
  4. Sep 6, 2013 at 4:53 AM
    ibuprofelin
  5. Sep 6, 2013 at 5:49 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    That's strange. Assuming that you followed the instruction exactly you shouldn't have any problem unless there is a difference in a 2008 diagram. I didn't give a hard look at the diagram in the picture on the write up but I don't know why it wouldn't work. Some one on here with much more knowledge about this kind of thing will surely jump in and help though.
    I like the idea though (not of the reversed heat/air) but the black face of the control.
  6. Sep 6, 2013 at 5:50 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Get a reverse sticker made. IE red is blue and blue is red. :notsure:
  7. Sep 6, 2013 at 11:08 AM
    ibuprofelin
    I could probably take a picture of the splicing that I did, but suffice to say, absolutely everything on the AC works aside from the direction of the dial that makes the air blow hot or cold. The thread that I linked to, the OP used another harness that plugged into the one inside the truck, then used that as an adapter to plug it into the 2012 one.
    The only noticeable difference between his wiring and the climate controls I have is that the grey AC wire is in Pin 13 on mine and Pin 16 is his. The AC button doesn't function when I move the AC wire.
    No idea how to fix haha. A mechanic buddy of my told me I could should be able to follow the wires to where they're plugged in the dash and switch around the two power wires there (it should have a triplet - two power wires and a ground) and that should fix it, but I can't find the harness in the dash and taking it all apart seems difficult.
    Hoping someone who has more experience can help. I appreciate the replies though!
  8. Sep 6, 2013 at 11:11 AM
    RearViewMirror
    Craig Christ
    I really like your idea and if you get it worked out I think it will look great. I hope you get it figured out.
  9. Sep 6, 2013 at 4:34 PM
    ibuprofelin
    I appreciate it! It looks great sitting in the truck, just need this one minor point to work out. I've been asking around trying to see if anyone has any ideas to fix it.
    Will definitely have the solution posted at some point, when I figure it out.
  10. Sep 6, 2013 at 5:46 PM
    RearViewMirror
    Craig Christ
    I'll be interested when you do (no doubt you will). I might do the same thing. I like the black with the white background.
  11. Sep 6, 2013 at 7:23 PM
    ibuprofelin
    Trust me, the difference in night and day between the 2008 dials and the new panels. It's ridiculous. Huge upgrade in the cabin with such a simple measure. Only trick is finding a set of climate controls, though I got lucky finding that and a clock fairly quickly by asking on the buy/sell/trade board.
  12. Sep 7, 2013 at 7:49 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    The temperature dial on the 2012 dials when all the way to Cold is sending a 0 volt supply to the truck, when all the way to Hot it is sending a 13.5 volt supply to the truck. 2005 to 2008 trucks are looking for the exact opposite, Cold is 13.5V and Hot is 0 V.
    It looks like since the ground is shared between the temperature dial and the selector switch pin 9 on the 2008 and pin 1 on the 2012, you can't just switch around the + and - wires to the temperature dial in the climate control and it work.
    If you did that it looks like you would switch the selector dial around to work backwards.
    The 2005 to 2008 wiring is different by this than the 2009 to 2011. I am guessing that the 2012 climate control is the same wiring as the 2009 to 2011's
    I tried a 2009 ac dial in my 2006 truck and the same thing that you are getting happened to me.
    If you could isolate the power supply to or from the temperature dial then you could switch the voltage around and it work right. This is my best guess going off the wiring diagram.
    Williston likes this.
  13. Sep 8, 2013 at 5:41 AM
    ibuprofelin
    Thanks for all the great information. To isolate the power supply, would I just follow the wire labeled AC back into the dash and see where it leads? I imagine it would be like my mechanic friend said and would split into a couple wires on the dash side. Does anyone know where in the dash this cluster of wires originates from?
  14. Sep 8, 2013 at 8:48 AM
    Jones
    Texas DFW
    I am not really sure if following the wires will work and which wire you are looking to find. To me it looks like the potentiometer for the dial is set up reverse in the 05 to 08 trucks than in the 2009 to 2011 trucks.
    Here is the voltage specs and the air conditioning wiring diagram from the 06 Factory service manual. I am pretty sure the 09 and up are different on the wiring. Either way something is different.
    I would test all the voltages coming out of the wires when the dial is turned each direction and see if that can help you find the one that you need.
  15. Sep 8, 2013 at 10:09 AM
    ibuprofelin
    Ok, so for example, with the climate control on the coldest setting, test the wires to see which would have 0 volts, and for the hottest setting which has 13.5 volts. Assuming everything works out and only two of the ten wires has a voltage of 0 and 13.5, I can just switch them and it should be reversed? Does that make sense? My electrical knowledge beyond theoretical is not very good.
  16. Sep 8, 2013 at 10:16 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Jones has it right...thisnhappesns as well if you add any 09-11 controls to a pre 09
    just flup the wires
  17. Sep 8, 2013 at 11:01 AM
    ibuprofelin
    Do you know which wires specifically to flip here?
  18. Sep 8, 2013 at 11:54 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Replying to your pm...I'd have to look for my papers where I wrote stuff down :anonymous: I don't remember off the top of my head lol
  19. Sep 8, 2013 at 12:04 PM
    ibuprofelin
    If you can find it that would be amazing haha. Really hoping got this to work iut
  20. Sep 8, 2013 at 1:45 PM
    Jones
    Texas DFW
    I am interested to know too. I have been looking at it this afternoon and wondering if I am even thinking about it correctly.
