AC Blows Hot When on Cold Setting and Cold When On Hot Setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ibuprofelin, Aug 25, 2013.
  1. Sep 12, 2013 at 4:19 AM
    ibuprofelin
    ibuprofelin [OP] Well-Known Member
    Bump for the answer!
  2. Sep 13, 2013 at 4:57 PM
    ibuprofelin
  3. Sep 30, 2013 at 2:25 PM
    silver streak taco
    silver streak taco Well-Known Member
    just switched mine out too and it blows hot on cold and cold on hot. any answers or did you figure it out?
  4. May 28, 2014 at 7:35 AM
    db2
    db2 Well-Known Member
    2016 TRD Sport DC
    I have a working solution for this! As Jones mentioned, pre-2009 Trucks use opposite voltage from the 2009-2014(?) trucks to control the temperature. The result is a backwards dial. The solution is to switch the contacts on the control knob so that it feeds reverse voltage from the original design. This is done by cutting the original circuit board connections, and rewiring the connections to the opposite pins of the control knob. One other note, like the OP, My A/C Control wire needed to be on Pin 13 (not 16) on the A33 Connector. My truck is a 2006, so I also needed to make a connector from the A16 connector to the A33 connector.
    Sorry I didn't take a picture, I was in too big of a hurry to get it back in the truck!!!
    The solution to this is as follows:
    1. Take apart the A/C Control panel, and isolate the circuit board.
    2. On the back side of the board you will find 3 pins coming from the Potentiometer (Control Knob)
    3. You will see 3 leads coming from the Control Knob. To get the correct orientation, rotate the board until the lead with the thickest "trace" is at the top (12:00) position, and the bottom lead is a "trace" that leads to a resistor. (note: on the graphic, you will not see the control knob as it is on the opposite side of the circuit board)
    4. With a razor blade, cut through the top 2 leads (Do not cut the bottom lead). This will disconnect the control knob from the circuit.
    5. With a razor blade, lightly scrape the "trace" of the top 2 leads to expose a small section of copper "trace". Then meter between the exposed "trace" and the lead from the corresponding control knob lead and make sure there is no connection. If you still have a connection, you need to cut deeper in step 4.
    6. Add a bit of solder to each of the exposed copper "traces" and cut two small wires and tin the ends with solder. Solder one wire to to one of the Control Knob leads, and to the opposite trace at the exposed copper trace. Repeat with the other Control Knob lead, and opposite trace.
    7. Meter between the Control Knob Lead and another point along the trace to make sure your solder connections are solid.
    8. Reassemble the A/C Controller and enjoy proper Cold/Hot Settings :)
    Dolphin1 and mit88 like this.
  5. Jan 25, 2015 at 7:10 PM
    bradforj
    bradforj Well-Known Member
    TN
    07 4x4 v6 TRD Sport
    2012+ Front End Swap 2014 steering wheel swap w/audio and BT controls 2014 power window controls 2014 lower center dash and radio bezel 2014 a/c controls Auto-dimming mirror Heated side mirrors Turn signal side mirrors Backup camera DNX890HD head unit Kenwood speaker system Kobalt slim toolbox In-channel Ventvisors N-Fab running boards
    Thanks for sharing this info and graphic. I now have proper hot/cold settings :)
  6. Jan 26, 2015 at 7:42 AM
    db2
    2016 TRD Sport DC
    You're welcome, sorry for the terribleness of the graphic :)
  7. Mar 26, 2015 at 6:49 AM
    steveh_2007
    steveh_2007 Pro Member
    NW Houston, TX
    07 TRD Sport PreRunner
    TRD Baja Suspension, FN Wheels BFD, TRD Cat-back Exhaust, TRD Cold Air Intake, TRD GrillCraft MX Grilles, FX-R 3.0 Bi-Xenon Retrofit with Osram CBI Bulbs, OEM Navigation/Bluetooth/Backup Camera Retrofit, WeatherTech Floorliners, Valentine One, ScanGuage II with custom V1/SGII BlendMount
    Would either of you being willing to perform this fix for me? I have a set of 2012 climate controls that I'm wanting to make plug n play on my 2007.
    I would pay shipping both ways? I know I couldn't be the only one on TW that's wanting to do this mod...
  8. Aug 18, 2016 at 8:05 AM
    motozack
    motozack Well-Known Member
    zack
    Humboldt Ca.
    '07 2015 TRD pro clone MAGNUSON supercharged
    Magnuson S/C 2.85 stealth pulley Afe stage 2 sealed pro dry 255 URD fuel pump TRD Quickshifter & knob Method double standards 265/70/17 KO2's B.A.M.F. Sliders W/kickouts powder coated 2.5" kings W/resi's Camburg UCA's TRD catback exhaust 2015 TRD pro clone 2015 interior Pioneer Nav
    Anyway to get the write up with photos?
    Have my parts just need to see what yo do! Thanks
  9. Dec 3, 2017 at 8:25 AM
    rogotoko
    rogotoko Well-Known Member
    R D
    Maryland
    2007 TRD Off Road 4x4
    Bluetooth Stereo, Backup Camera, Viper Remote Start, Heated Seat Kit, Extang Solid Fold Tonneau Cover.
    I wish I'd have read this before I put a 2010 temperature controller in my 07. It would seem to me, however, that there's a way to switch the wires in the harness, as well. Has anyone remedied the issue that way? I had to replace mine because my previous board was boogered up and I just don't want to go cutting into the new one.
  10. Dec 4, 2017 at 12:17 PM
    rogotoko
    R D
    Maryland
    Ok, I didn't get any responses (I know it's an old thread) but I got the volt meter out and did some checking myself. It seems that the internal mod is the best option. Funny thing is, that side by side, the pre-2009 board and post-2009 board are identical. Even the resisters are the same. Long story short, the mod is done and working perfectly. Thanks for the write-up on this. I found it easy to follow. 20171204_151054.jpg
    steveh_2007 and Brice like this.
  11. Sep 4, 2021 at 4:50 PM
    airkewled
    airkewled Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    Since @d2 post was super helpful, I'll post of this picture of what the directions describe. This worked perfectly for me
    Corny Taco likes this.
  12. Jan 16, 2024 at 2:26 PM
    leerich22
    leerich22 New Member
    Lee
    2008 Tacoma access cab 2.7l, 5 speed manual, 4x4, 140k miles.
    3.5 inch lift, steel off road bumpers, aucar tesla screen, console safe, 16x10 wheels with 305/70/16 tires around. Header, custom exhaust, auxbeam 8 switch bluetooth panel/dist box, ditch lights, fog lights, light bar and alpharex headlights. Backflip bed cover, locking and camera tailgate handle.
    I have the Aucar Tesla Screen installed and I have a 2008 and of course the hot is cold and the cold is hot. I've been driving like that for about a year now, but it just bugs me. I was hoping someone had solid details on tricking the truck into switching them around instead of doing it electronically since Aucar has very limited support other than buying.
  13. Jan 16, 2024 at 3:00 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The Mode and Temp actuators use a 0-12v linear control voltage on Pin 2, as the voltage increases or decreases the actuator moves accordingly.
    You would need a way to reverse the voltage output to the actuator or use an actuator from a 09-15 truck, it's not well documented but the 05-08 actuators and 09-15 actuators use opposite control voltages (05-08 12v is max cold and 0v is max hot, 09-15 0v is max cold and 12v is max hot).
    In fact it's very had to find a temperature actuator for an 05-08 truck because the superseded part# according to Toyota fits 05-15 trucks but will operate backward on 05-08 trucks, even some sections of service info have the wrong voltage specs on them.
    GrandTheftAngel likes this.
  14. Jan 16, 2024 at 3:25 PM
    leerich22
    Lee
    Sounds like I shouldn't have thrown away the perfectly good 2008 controls once I got the Aucar working.
  15. Jan 16, 2024 at 3:27 PM
    #35
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Is there not a setting to reverse the output?
  16. Feb 15, 2024 at 8:05 PM
    #36
    GrandTheftAngel
    GrandTheftAngel Well-Known Member
    Angel
    I'm having this issue on my 2008 taco. the cold setting blows hot and the hot settings blows cold. Very odd. Any simple fix to this? no biggies if not it's just so weird
  17. Feb 15, 2024 at 8:08 PM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you recently replace the temperature actuator?
  18. Feb 15, 2024 at 8:10 PM
    #38
    GrandTheftAngel
    Angel
    I'm not sure what that is, unfortunately. But I did replace the stock temp controls with a 2nd gen aucar headunit
    Dm93[QUOTED] likes this.
  19. Feb 15, 2024 at 8:16 PM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ah I'm not sure about that but I explained how they work in the post (#33) above.
  20. Feb 15, 2024 at 8:20 PM
    #40
    GrandTheftAngel
    Angel
    Yeah, I saw - I didn't understand it but sounds interesting. the headunit just plugs into the ac and temp controls
