AC Button will not turn off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sawx75, Sep 24, 2018.
  1. Sep 24, 2018 at 3:56 AM
    sawx75
    sawx75 [OP] Active Member
    Massachusetts
    2010 Red TRD Off Road
    So my AC button will not turn off. Hot, cold, whatever, the button stays lit up and cold air blows out no matter the temp I select. Is there any way to fix this, or do I just replace the climate control unit?
    Thanks in advance for any help, it's starting to get cold here and I need to fix this ASAP.
  2. Sep 24, 2018 at 5:42 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Check the blend doors air mix control servo and mode control servo 2012-01-30_212131_pic.gif
  3. Sep 24, 2018 at 9:42 AM
    sawx75
    Massachusetts
    I bought a Climate Control Unit off ebay. Will report back if it works or not.
  4. Sep 24, 2018 at 1:55 PM
    sawx75
    Massachusetts
    Ok, so I bought the wrong unit and the seller is swapping it for the right one. If I swap out the unit, think that will fix my problem?
  5. Sep 24, 2018 at 1:57 PM
    k5driver
    k5driver I hate bums
    Montana
    2009 4x4 DCSB MT SR5
    Maybe this sounds dumb... but once you moved the knob off of MAX A/C, you have pushed the A/C button again, right?
    KTM753 likes this.
  6. Sep 10, 2024 at 11:15 AM
    Cisen
    Cisen New Member
    2010 black TRD offroad
    Was this issue resolved? If so how?
