AC/Circulate Buttons Lights Turn Off
Discussion in '1st Gen. Tacomas (1995-2004)' started by BluEyeItln, Aug 30, 2023.
  1. Aug 30, 2023 at 8:40 PM
    BluEyeItln
    BluEyeItln [OP] Member
    Richard
    01 Tacoma 4-Door 4x4
    I'm hoping someone has experienced this. I had my dash apart coloring my needles as well as connecting replacement radio and after putting it all back together, my ac and circulation lights do not come back on after starting back up. Meaning I have them on and after turning off the engine those lights do not come back on. I press the button to turn them back on and its all working but each time they turn off, they don't stay on upon restart as they always have.
    Any knowledge to possible fix?
    Found threads on many types of Toyota's with this issue but couldn't find their fix.
    Bivouac likes this.
  2. Aug 31, 2023 at 5:05 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If I understood what your saying Your AC is being used while the engine is running.
    You shut the engine off upon restarting the AC is shut off and needs to be powered up again.
    Since this did not happen till you pulled things apart some place you missed something or hooked up something wrong. No idea to have any idea just what you did. One of those up close and personal problems
    Did you not use the stock radio Harness ? Making it a plug and play install?
    Here you go Happy Trouble shooting down load this so you have it on hand.
    Good Luck!
  3. Aug 31, 2023 at 6:55 AM
    BluEyeItln
    Richard
    Thank you for responding. Both the AC and Circulation lights turn off once the truck is turned off. So I have to turn them back on once I start it up. The radio is installed with the stock harness and had no issues with any of that. It's a weird occurrence as everything is plugged back in and connected to what they were before. Might have to unplug and re-plug them all. Maybe connection didn't complete when connected.
