AC Clutch Failure - How to fix! (blinking light, squealing)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N75, Aug 27, 2016.
  1. Sep 22, 2018 at 11:12 AM
    #221
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Yeah this is what I'm dealing with right now I had to take the Fan off after dropping the fan guard and now I'm in there trying to grip the edge and work it off
  2. Sep 22, 2018 at 11:22 AM
    #222
    TreeFortRichard
    Brian
    This thing is so hard to get off it feels reverse threaded I can barely get any purchase with the vice grips and not be in the way of the ratchet head
  3. Sep 22, 2018 at 11:36 AM
    #223
    TreeFortRichard
    Brian
    Victory. That was just as much of a rusted pain in the ass as everything else on the Tacoma. Look at all that free space
  4. Sep 27, 2018 at 5:39 PM
    #224
    338Lapua
    338Lapua Member
    Christian
    Las Vegas, NV
    2010 TRD Sport
    Thank you OP just had this happen and decided to go your route first instead of letting someone rip me off and wouldn't you know it, IT WORKED !!!! Thanks again.
    TreeFortRichard likes this.
  5. Oct 4, 2018 at 4:55 PM
    #225
    topoutman
    topoutman Well-Known Member
    Ellensburg, WA
    2013 DCLB 4X4 TRD SPORT
    Isn’t it great when things actually work out!!! Such a great feeling fixing this before dropping a s*** load of $ and/or time into it.
    338Lapua[QUOTED] likes this.
  6. Nov 17, 2018 at 11:23 AM
    #226
    BackInTaco
    BackInTaco Member
    MA
    06 4x4
    This thread just saved me a bunch of money, thanks OP.
    4cyl, so loosening the fan shroud and removing the fan blades gave me just enough room to get at it.
  7. Feb 8, 2019 at 9:13 AM
    #227
    bestshooter
    bestshooter Member
    Toyota Tacoma
    What if while observing this the pulley spins and the clutch engages and spins then cuts off?
  8. Feb 8, 2019 at 9:21 AM
    #228
    Clearwater Bill
    Billy
    Largo Florida
    Then likely the clutch is good, and the system is being shut off via a safety mechanism, like low or high pressure.
    Jimmyh likes this.
  9. Feb 8, 2019 at 10:57 AM
    #229
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    This^
    When it shuts off, does it restart a few seconds later? Then shut off again? If so, likely low on freon.
    Jimmyh likes this.
  10. Feb 8, 2019 at 11:06 AM
    #230
    bestshooter
    bestshooter Member
    Toyota Tacoma
    No once it cuts off it stays off .. in my quest to check if it was low on Freon I hooked up a quick charge gauge and when it is on it’s a little high but still green when it kicks off the pressure is high on low pressure side in the red . Don’t know if this helps but I’m pretty sure it’s not low .
    Think the only other possibility is the ac amplifier maybe .. if anyone has any other ideas I’d love to hear . Now how do I get the amplifier out ?
  11. Feb 8, 2019 at 2:51 PM
    #231
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    That's normal, it's probably not low. When it kicks out, do you have to turn off the AC to get it to restart, and/or does the AC light blink? AC amplifier is behind the glove box, I think. @Jimmyh can put up a diagram. I kinda doubt it's the amplifier.
    Best thing now is to hook up a gauge manifold and post the numbers, low and high, when it quits. Again, does the AC light start blinking?
    Jimmyh likes this.
  12. Feb 8, 2019 at 3:09 PM
    #232
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  13. Feb 8, 2019 at 4:03 PM
    #233
    bestshooter
    bestshooter Member
    Toyota Tacoma
    Ya that’s what I’ve been trying to troubleshoot was the blinking ac light . When I turn the ac on it comes on for just a couple seconds then cuts off and starts flashing . I replaced the relay and watched the clutch engage and the compressor spin. The clutch appears ok there’s no black leaking like others have had , it looks good (not sayin it is but appears to be and appears to work by engaging ). Not sure where else to look other than the compressor pickup sensor. If it’s that then I’d prob be better off just ordering a new compressor I would think .
  14. Feb 8, 2019 at 5:00 PM
    #234
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    Sub for later
  15. Feb 8, 2019 at 6:18 PM
    #235
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    This would be my guess now. IF the compressor is turning as fast as it should. Sensor is a lot cheaper than a compressor.
    Blinking light means compressor rpm is not matching engine rpm. Or, the sensor is shot.
    Jimmyh likes this.
  16. Feb 8, 2019 at 9:25 PM
    #236
    bestshooter
    bestshooter Member
    Toyota Tacoma
    If it is that sensor it appears I need to order it with a compressor as I don’t think I can order it by itself and I still have to take the compressor out and have it expelled and refilled I believe if I read it correctly .
  17. Feb 9, 2019 at 6:25 AM
    #237
    Jimmyh
    SC
    2012 Prerunner SR5
    There is only one bolt holding the sensor in place. You should be able to get it from the bottom without removing the compressor.
    http://www.customtacos.com/tech.old...6toyrm/06toypdf/06rmsrc/rm2006ta/04600710.pdf
    http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/046007.pdf
    See the second document above shows how to test the sensor magnetic pickup.
    The part number for the Sensor only is: Part Number: 8834604010
    https://parts.westcoasttoyotalb.com...--COMPRESSOR-PICK-UP/63188737/8834604010.html $92.00
    https://parts.olathetoyota.com/oem-parts/toyota-sensor-compressor-p-8834604010 $97.00
    https://toyotaparts.mcgeorgetoyota.com/oem-parts/toyota-sensor-compressor-p-8834604010 $86.00
    They are a bit pricey however, about 100 bucks. I would remove the one in the truck and test it above in the pdf first before spending 100 dollars.
    billnye1999 likes this.
  18. Feb 9, 2019 at 11:03 AM
    #238
    bestshooter
    bestshooter Member
    Toyota Tacoma
    Great thanks , I’ll give that one a shot and see if that is the culprit.
  19. Jun 18, 2019 at 7:31 PM
    #239
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Did any of you guys have PAG oil around the shims/splines on the compressor/clutch?
  20. Jun 18, 2019 at 7:38 PM
    #240
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I would think if it's for sure PAG oil the you might need a new compressor, unless you want to try to reseal it.
