AC clutch install SUCCESS!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wannabe4x, Jun 27, 2021.
  1. Jul 20, 2021 at 1:58 PM
    Wannabe4x
    Wannabe4x [OP] Well-Known Member
    Conner
    EastCounty, SanDiego
    2nd gen TRD PreRunner
    Spindle lift, 285/70/17s, Methods
    And going from the fact that you see your clutch engaging but no cold air worries me to think that either your compressor took a crap or you’re super low on refrigerant. Normally low refrigerant can cause it not to cool down to temp, but extremely low refrigerant can cause a compressor failure. If you’re not hearing a grumbling sound when you turn the ac on usually that means the compressor is still good. Are you having the AC blinking light issue like I was?
  2. Jul 20, 2021 at 1:59 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    no the light was not blinking. Its just odd, because I rarely use my AC. Only really for defrost
  3. Jul 21, 2021 at 11:05 AM
    fatfurious2
    David
    Ashburn, VA
    Welp, i have a new clutch, but no ac. Going to try one of those recharge bottles next. But job was fairly simple, except my bearing was stuck on. Had to use a 3 jaw puller to get off
    llamasmurf likes this.
  4. Jul 21, 2021 at 1:30 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Yea we had to use a puller as well. It is a pretty tight place to get the puller into. Lucky my bud had one small enough.
    fatfurious2[QUOTED] likes this.
  5. Jul 21, 2021 at 2:01 PM
    Wannabe4x
    Conner
    Dang! And if it were me I’d go to a shop to have the system tested.. it cost me $90 and they evacuated, looked for leaks and put back my Freon, only adding a small bit. Those canister ones are sketchy and you can easily overcharge your system causing it to fail. My .02
  6. Jul 21, 2021 at 2:05 PM
    fatfurious2
    David
    Ashburn, VA
    Ok thanks for the tip! Ill try to get it done. I have a trip coming up.. VA -> Montana (stopping in SD :boink:) and AC would be nice to have, but not necessary for me.
  7. Jul 21, 2021 at 2:29 PM
    Wannabe4x
    Conner
    Depending what time of the year.. :bananadead:
    fatfurious2 likes this.
  8. Apr 23, 2024 at 3:08 PM
    grad3r
    grad3r Active Member
    Hi, anyone know torque on the bolt?
    goforbroke123 likes this.
