Ac clutch rebuild vs complete compressor relpacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kerrp, Aug 1, 2015.
  1. Aug 1, 2015 at 4:40 PM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    06 red taco 4 banger
    Today I replaced the clutch relay and still no dice. Light blinks warm air and a squeal. The squeal stops after a few seconds.
    Someone told me its the clutch. Is it worth rebuilding the clutch for 100$ or replacing the compressor and clutch for 190$
  2. Aug 1, 2015 at 5:24 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Clutch is slipping because compressor is seizing probably due to high pressure [overcharge, low air flow through condenser, low oil in system or clogged expansion valve] you need to run pressure test if pressure is good then probably bad compressor. Clutch's rarely fail without cause.
  3. Aug 1, 2015 at 5:27 PM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    Correct me if I'm wrong on this. Wo the ac running the pulley on the clutch just spins when you turn the ac on, the center of the pulley the clutch spins also. I get no spin in the clutch none that I see anyway
  4. Aug 1, 2015 at 5:37 PM
    bubbabud
    Bob
    Tonopah AZ
    Possible the clutch coil is unplugged or burnt out also a chance you are low on refrigerant and the low pressure cut switch is turning the compressor off shortly after start up but this would not explain the squeal
  5. Aug 1, 2015 at 5:41 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    With AC off, the outside of the clutch turns with the belt. The inside does not. When AC is on, the inside will turn along with the outside.
  6. Aug 1, 2015 at 6:00 PM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    Yep inside no turning. So I've been reading and says I need to check all electrical / electronic connections as the blinking light means there is an electronic malfucktion. I'm wondering if changing the filter just allowed the truck to read that the pressure switch is bad.
  7. Aug 1, 2015 at 6:37 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    With the truck running, have someone push the AC button while you watch the compressor clutch. Does the inside start turning then? Does it squeal then? Keep watching and have the helper tell you when the blinking starts.
    I doubt the cab filter has anything to do with this problem.
  8. Aug 1, 2015 at 7:13 PM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    That's the next step
  9. Aug 2, 2015 at 8:18 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Shut the engine down. Try turning the compressor by hand - off the front face of the clutch. It should have a bit of resistance, but should be smooth. If you can't turn it, or it feels rough, the compressor is the issue, not the clutch.
  10. Aug 2, 2015 at 8:33 AM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    I'm gonna try that as soon as I can. Update. I tried turning the ac on again , this time at 60+ mph. No cold air, but no blinking light either. I'm wondering if I'm just low on freon,
  11. Aug 2, 2015 at 8:50 AM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Low refrigerant won't cause a squeal though - that would be belt or clutch slippage, the cause of which needs to be determined. Could be as simple as a worn belt, weak tensioner, or more serious like excessive high side pressure from an expansion valve failure, or the compressor is seized.
  12. Aug 2, 2015 at 9:40 AM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    Funny you mentioned the squeal. That's stopped too
  13. Aug 2, 2015 at 10:36 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    So is the center of the clutch turning with the AC on, or not? Only takes a few seconds to look...
  14. Aug 2, 2015 at 10:37 AM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    Nope. Doesn't turn
  15. Aug 2, 2015 at 11:34 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    You might be so low on freon that the low pressure switch is preventing the compressor from running. However, since you had a squeal, I suspect that the compressor was eating itself up and the metal fragments took out the shaft seal. You need professional help to diagnose, with a gauge manifold.
    Lester Lugnut likes this.
  16. Aug 2, 2015 at 11:37 AM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    Hmm so to a mech it goes.
    Anyone in the Richmond area know of a good mech who they trust? Who won't take me to the cleaners
  17. Aug 2, 2015 at 11:49 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Richmond is only about 30 miles from me... Richmond, KS that is. ;)
    Good luck.
  18. Aug 2, 2015 at 11:50 AM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    I guess I should have specified Richmond Va.
    CurtB likes this.
  19. Aug 2, 2015 at 11:50 AM
    Kerrp
    Kerrp [OP] Member
    RVA baby
  20. Aug 2, 2015 at 12:17 PM
    Kerrp
    Kerrp [OP] Member
    RVA baby
    Another quick question. How do I check ac pressure when the compressor isn't turning?
