AC cold but Fan Intermittent
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdintexas, May 19, 2013.
  1. May 19, 2013 at 3:56 PM
    jdintexas
    jdintexas [OP] Member
    JD
    Texas
    2007 Prerunner V6
    none yet
    AC is cold but my AC fan will just stop.
    It will work on occasion but not always.
    Also, if I turn off the interior circulation and use just the vent with AC on
    I can get a cool breeze... ahhh.
    It's about to get warm in Texas
  2. Jun 11, 2013 at 3:04 PM
    jlb5035
    jlb5035 Well-Known Member
    Josh
    Raleigh, NC
    01 PreRunner SR5
    Tint, Billet Grille, JL Audio and Focal stereo, maybe more
    I have the same problem with my 01. If you happen to run across a solution I'd be eager to hear it, or if I run across a solution I'll post it here.
    I did find that with mine if I leave the fan on whenever I shut the truck off if has a better chance of coming back on the next time I start it up.
  3. Jun 11, 2013 at 3:17 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    My money would be on a sticky fan power relay. Though I would start simple. Check that all the fuses and connections are tight. Check for a good 12v at the fan connector and a good ground. Work your way back from there
  4. Jul 10, 2013 at 10:12 AM
    jlb5035
    Josh
    Raleigh, NC
    01 PreRunner SR5
    A little late getting back on here but I finally had time to look into it. There was 12v at the blower motor so I removed the motor and the plastic case surrounding the motor and checked it for any damage or corrosion but didnt find any. Once the plastic covering was off I plugged the motor back in to test and it worked just fine. Weird but good enough for me so I put everything back tightly and it has been working normally for about a week now.
    The best explanation I can think of is that maybe by unplugging and plugging it back in a couple of times I caused something to make a better connection at the plug or inside the metal casing of the motor. If it happens again I will probably just buy a new blower motor since they are only about 40 bucks.
