Ac cold drivers vent only
Discussion in 'Hawaii' started by hemitruk, Aug 7, 2016.
  1. Aug 7, 2016 at 9:10 PM
    hemitruk
    hemitruk [OP] Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Any one had problems with ac blowing cold only from drivers vent ? Other vents blow warm. Seen couple post one said he recharged ac and works good now .Drivers vent was 48degrees and clutch not cycling on and off so think freon ok.
    Extended warranty expires in couple months so guess will take it in . Wanted to see if might be a vent door or some thing before I take it in.
  2. Aug 7, 2016 at 9:13 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2021 Tacoma TRD Off Road
    No freon. Mines was like that, then started seeing fog coming from vents, then no cold air at all.
    Toyko Joe and hemitruk[OP] like this.
  3. Aug 7, 2016 at 9:16 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Ok thanks . Must have leak than .Guess will be taking in for warranty.
  4. Aug 8, 2016 at 11:44 PM
    xurusaibobx
    xurusaibobx Well-Known Member
    most likely low refrigerant and leaking evaporator. pretty common on the 05- up tacomas/4runners
    hemitruk[OP] likes this.
  5. Aug 9, 2016 at 9:00 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Good to know . What threw me off is clutch not cycling like low freon . Damn servco got 1 month wait for open appointment. Hope ac doesn't crap out completely...lol But then again might be good they can change more things under warranty. Thanks
  6. Aug 9, 2016 at 9:22 AM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Have you tried contacting the other Servco Toyota service departments? They might be able to get you in quicker.
  7. Aug 9, 2016 at 1:44 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    No never tried others.Vacation week of appointment and live saltlake so might keep it at mapunapuna unless ac gets worst.
  8. Aug 9, 2016 at 1:49 PM
    seoulja99
    E.J.
    Oahu
    If it does get worse, I would contact Waipahu or even Windward. Usually a quicker option.
  9. Aug 9, 2016 at 2:40 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    That's what drives me nuts about servco. They wanted me to wait 1 month to fix a nail in my tire. Said I had to bring in the vehicle not just the tire, and I could leave the truck and they would fix it "if they had time"
  10. Aug 9, 2016 at 8:27 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Yea guess they take the money jobs first not warranty work. Shows how much they care about there customers.
  11. Aug 9, 2016 at 10:02 PM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    A/C Compressor clutch not cycling is not a normal condition. If it's not coming on at all, it could mean low freon. If it's staying on, something else. But normally, it should cycle.
    That sucks ass.
    I just assumed that warranty work was money, maybe even better money if its all insured. Or maybe that's just extended warranties.
  12. Aug 9, 2016 at 10:17 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    As far as ac cycling I monitored for like a minute or two not very long. When driving cannot really tell. Thinking maybe compressor starting to crap out plugging evap or filter .
    Heard on warranty work dealers don't get as much money as if wasn't warranty.
  13. Aug 10, 2016 at 8:41 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    think they do work at a set rate(which is less than standard hourly) but paid by the warranty money pot from manufacturer.
    say if they have a bay of 10 lifts, they might keep 1 for warranty stuff, which could explain the month wait.
    Robman and hemitruk[OP] like this.
  14. Aug 26, 2016 at 3:50 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Got gauge hooked up . Yup low on charge . Hopefully evaporator so can get the most of my warranty. 2 more weeks to wait for appointment called windward Toyota 1 month wait :facepalm: Guess I just wait 2 more weeks. Took off today .... Now time to get drunk and watch the warriors .....Go Bows....
  15. Sep 8, 2016 at 11:37 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    So was evaporator. Picking up today . Almost 1 month without ac sure sucks . 1st time in many many years with out ac . I say don't leave home without it lol....
    they also changed expansion valve
  16. Mar 26, 2017 at 1:55 AM
    Waited many moons
    Waited many moons Well-Known Member
    Pat
    Honolulu, Hawaii
    2014 Alaska Edition
    Did they change your dryer? That should have been changed also.
  17. Mar 26, 2017 at 11:04 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Nope .You know Servco. Told them about ac controller could see signs of 1 terminal overheating but they said tech said nothing wrong .
