AC cold on driver side, warm on passenger side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TeardropTaco, May 4, 2025.
  1. May 4, 2025 at 6:40 AM
    TeardropTaco
    TeardropTaco [OP] New Member
    '17 SR5, DBL, LB
    Victory 4x4 Racks, concealed ammo cans behind fenders, fumoto oil drain valve, LED lights
    Anyone have cold AC on just the driver side vents and warm on the passenger side vents? I'm assuming its a blend door that is not fuctioning correctly. 2018 SR5, dbl cab
  2. May 4, 2025 at 6:44 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Possibly low on refrigerant. Worked on a couple cars with that same issue.
    VTCAL, Chew, Tacoma Mike and 2 others like this.
  3. May 4, 2025 at 8:59 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Chew likes this.
  4. May 4, 2025 at 10:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    yeah, probably low on refrigerant, this is common as the coil is on the passenger's side. It's essentially not cold enough to get cool air through the rest of the system. I would get it to a known A/C tech for proper diagnosis and avoid the Can-O-cool at the local Otto-Zone.
  5. May 4, 2025 at 6:35 PM
    TeardropTaco
    '17 SR5, DBL, LB
    Thanks for the suggestions. My brain was fixed on thinking a blend door was stuck. Didn't think low refridgerant would still allow one side to be nice and cold while the other side wasn't. I figured low refrigerant would apply equally to all vents.
  6. May 4, 2025 at 6:46 PM
    stielinc
    stielinc Well-Known Member
    yea I would of guessed blend door too.
  7. May 4, 2025 at 7:09 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    It could be, I was just adding another possibility. I'd avoid the swap-a-part approach, it ends up costing more in the end.
    GL
    t0p_d0g likes this.
  8. May 5, 2025 at 4:59 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    If you have dual zone then I would say sync them depending on your trim. If not probably the door like mentioned.
  9. May 5, 2025 at 9:08 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    The A/C line schrader valves tend to be leaky on these trucks. I would get those checked. Had the same issue on mine, same symptoms as well cold on one side warm on the other.
    TXpro4X4 likes this.
  10. May 5, 2025 at 9:12 PM
    Bishop84
    Bishop84 Well-Known Member
    Its very common for this to happen with a low charge.
    Chew likes this.
  11. May 5, 2025 at 9:15 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I had a leaky hose
