AC compressor clicking/rattling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drew12, Dec 29, 2017.
  1. Dec 29, 2017 at 6:22 PM
    Drew12
    Drew12 [OP] Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    hey guys, lately I’ve been hearing this terribly loud front end rattle. I finally tracked it down to the ac compressor seems to click and rattle when I go over bumps/slight inconsistencies in the road/etc. not like the compressor itself is bad, but maybe mounts or something. Anyone have this problem?? Where are the mounting bolts/brackets that I can try and tighten? It’s pretty hard to see in there
  2. Jan 2, 2018 at 9:48 AM
    Drew12
    Andrew
    Sisters, Oregon
    Bump
  3. Jan 2, 2018 at 11:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Probably a worn clutch and pulley.
  4. Jan 2, 2018 at 6:10 PM
    Drew12
    Andrew
    Sisters, Oregon
    Would that make it so there’s only a clicking noise when hitting small bumps? It doesn’t do it at idle and usually only once I’ve let off the gas... which makes me believe that it doesn’t happen while accelerating because there’s load on the pulley.
  5. Jan 2, 2018 at 7:42 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    I have a crazy rattle behind my glove compartment when the heater is turned on. Only happens when I'm blowing heat and not
    during cold a/c. :facepalm:
  6. Jan 2, 2018 at 9:17 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I have no way to know that or not. I was only using your statement that you have it narrowed down to the AC Compressor.
    You should be able to grab the mounting with your hands an verify if they are loose or not.
    The most probable rattling noise from the AC Compressor would be a clutch pulley issue.
  7. Jan 2, 2018 at 10:17 PM
    Drew12
    Andrew
    Sisters, Oregon
    Gotchya. I will investigate further when I have some time! Thanks man
