AC Compressor condensation is leaking an abnormal amount.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Roadie_, Jun 17, 2025.
  1. Jun 17, 2025 at 11:48 AM
    Roadie_
    Roadie_ [OP] Active Member
    Humidity and hot weather has struck and I've been blasting the AC on Max. AC is ice cold and working as should, however I've noticed the compressor seems to have much more condensation than normal. I'm talking a pretty substantial puddle after parking, approximately 2ft in diameter.
    Could this be from a clogged drain line somewhere? Where would that line be?
  2. Jun 17, 2025 at 11:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    If the condensate drain was clogged most of that water would be sloshing in the evap box and leaking on your passenger carpet.
    Unless I'm misunderstanding what you are describing, it sounds perfect as is.
    Fl boy here, run AC 9-10 months of the year. Puddles are good.
    Stuck in VT and Roadie_[OP] like this.
  3. Jun 17, 2025 at 11:53 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Normal. If it’s not leaking into the floorboard of the truck, then the line is not blocked.
    Sounds completely normal for AC on max and high humidity.
    I’d say your ac is working great and efficiently. Other wise, you’d have less water.
  4. Jun 17, 2025 at 11:53 AM
    Glamisman
    Glamisman Well-Known Member
    No, normal operation. Youu could squeeze the tube where it exits the firewall to see if there is anything crunchy in there partially blocking the tube.
  5. Jun 17, 2025 at 11:56 AM
    Roadie_
    Great to hear that this is the consensus! Passenger floor board is dry so all good here.
  6. Jun 17, 2025 at 12:19 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Years ago, the ex took her car to jiffy lube prior to a roadtrip. Halfway to the outer banks, the passenger floor is soaked. Called my mechanic for advice..said it sounds like the condensate drain is plugged..pull up over a curb to get a look..see a bolt jammed in the hose..pull that out and promptly drenched in a flood of water..problem fixed..J.lube denied responsibility but clearly this was a trick the guy in the pit used to avoid dripping water on hot days and forgot to remove..J.L. claimed it was a senior tech..believe them..however, he forgot to pull the plug.. frustrating but quick fix.
