AC Compressor Go Boom!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hazard2600, Aug 15, 2025.
  1. Aug 15, 2025 at 9:55 AM
    hazard2600
    hazard2600 [OP] Well-Known Member
    Ted
    Watertown, TN
    2009 White 4x4 SR5 TRD Sport LBDC V6
    3" ProComp sus lift 2" Roger Brown body lift 33" BFGs ko2s 1.25" spidertrax wheel spacers Custom rock sliders Seat covers USB ports OBD2 computer monitor
    So, my '09 AC finally did it's battle cry of death and went out and I'm researching the heck out of how to replace it all. Since I've never replaced AC before. From the looks of it, Four Seasons seems to be the brand most folks on here are happy with. Other brands seem to be failing within a year.
    My question is, do I need to replace the Evaporator core? I believe that is in the cab and would be a pain to get to. I'm replacing everything including the hoses 'cause why not since I already have it all a part. I'm hoping I could just flush that.
    This is my parts list thus far:
    Valve Core & Cap Kit Part:30031-05081235 $4
    https://www.rockauto.com/en/moreinfo.php?pk=1251283&cc=1442967&pt=6992&jsn=1110
    O-Ring & Gasket Kit Part: 30031-05151175 $26
    https://www.rockauto.com/en/moreinfo.php?pk=1532558&cc=1442967&pt=13290&jsn=1105
    Discharge Line $22
    https://www.rockauto.com/en/moreinfo.php?pk=2196102&cc=1442967&pt=6900&jsn=1071
    Suction Line $57
    https://www.rockauto.com/en/moreinfo.php?pk=2196066&cc=1442967&pt=6900&jsn=1076
    AC Filter $3
    https://www.rockauto.com/en/moreinfo.php?pk=3578106&cc=1442967&pt=15479&jsn=1081
    FOUR SEASONS TSN4211 $331 (Compressor, Condenser, Expansion Valve)
    https://www.rockauto.com/en/moreinf...Z60JqHv83nS4M9ZtkJ+lAYA4c7FgtmhWTkQBsKg9iKg==
  2. Aug 15, 2025 at 3:34 PM
    GreaseForPeace
    GreaseForPeace Well-Known Member
    Rob
    2014 Black Tacoma SR5
    Have the system evacuated, replace the compressor and receiver dryer/filter, have a shop hold it under vacuum to confirm there are no leaks, then have them charge it. Unless you like A/C work, that's a whole lot of stuff that doesn't need to be replaced, if you're concerned about leaks get new o-rings for the lines and connections. There's no reason to replace the oe toyota stuff with aftermarket if it isn't leaking.
  3. Aug 15, 2025 at 4:25 PM
    ieizxxnsaeomeostfd
    ieizxxnsaeomeostfd Well-Known Member
    2014 Tacoma Base
    ARB Bumper Warn winch Icon lift 35s
    Jimmyh likes this.
  4. Aug 16, 2025 at 9:22 AM
    Rynedude233
    Rynedude233 New Member
    Same thing just happened to me. When i took it apart i didn't see a bunch of debris in the hoses so i only replaced the compressor. ChrisFix on YouTube did an awesome video for how to replace the compressor. If i did it again i would have a shop charge the new system, the crappy valves you buy at AutoZone were not very accurate or helpful
  5. Aug 16, 2025 at 9:48 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    A shop here cuts open the old receiver drier looking at any contamination anytime they are replacing a compressor. I was told since it's filtered there it's a sure telltale if the system has spit out a bunch of garbage into the lines.
    hazard2600[OP] likes this.
  6. Aug 16, 2025 at 10:08 AM
    hazard2600
    Ted
    Watertown, TN
    That's a great Idea. I'm going to do that for sure.
