AC compressor not kicking on
Discussion in '1st Gen. Tacomas (1995-2004)' started by NoTactJack, Aug 31, 2019.
  1. Aug 31, 2019 at 7:56 PM
    NoTactJack
    NoTactJack [OP] Beekeeper TxLawDog Master Brewer
    2001 maroon Tacoma SR5 4x4 3.4
    Ok well im working on a 2001 4wd xtracab v6 3.4 Tacoma.
    I pulled the evaporator box and all the dash out a few days ago chasing a coolant leak. My ac compressor had been making a horrible noise for like 18 months anyway so since I had to pull evap to get at the heater core I figured why not square that stuff away. New condenser, dryer, compressor, expansion valve, orings. Well I pull a vacuum, then try recharge the system through the yellow hose. And I low side and high pressure builds up to 120 but as far as I can tell my compressor never kicks on. The compressor clutch is plugged in. The pressure switch is plugged in too. The compressor came with 5 oz of oil pre installed, also I added the 1.4 oz of oil to the evap as the manual states.
    Any ideas?
  2. Aug 31, 2019 at 8:04 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I think you could narrow it down pretty quick with a multimeter. Check to make sure the switch is switching first, and if it is, start chasing down the compressor wiring.
  3. Sep 1, 2019 at 9:53 AM
    NoTactJack
    I found it. The plug on the new compressor was not secured very well l, when unhooked it up the spade end pushed out. All charged up and ac blowing cold.
    0xDEADBEEF likes this.
