AC compressor (or how the hell do you get to lower bolts)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DougM_SD, Jul 24, 2023.
  1. Jul 24, 2023 at 6:16 PM
    DougM_SD
    DougM_SD [OP] Member
    Doug
    Lakeside CA
    2015 Tacoma Shortbed 2WD
    Icon suspension front/rear, Deaver leafpacks, BFG AT
    So im working on my 2015 Tacoma - Sadly my belt tensioner needs replacing and to get this part out, they built the truck artound it!
    SO I need to get my A/C compressor loose to roll it out of the way to get top the bolts for the tensioner behind it. I have the alternator completely out already as well as the battery.
    I go the upper 2 out, but the lower 2 are a PITA!
    Any tips/tricks to get to these and remove easier ??? its 95* out this week so this should be more then fun.
    thanks,
    Doug
  2. Jul 24, 2023 at 6:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Remove the drivers side wheel.
    Go in through the wheel well?
    JustAddMud and muddog321 like this.
  3. Jul 24, 2023 at 6:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    GearWrench ratcheting wrenches, just don't back the bolts out too far where the wrench won't come off...
    TnShooter and DougM_SD[OP] like this.
  4. Jul 25, 2023 at 2:39 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Yep remove drivers side tire support securely on jack stands.
    Lots of extensions and a swivel. Take your time and you need to try several paths thru the suspension to get on them. Leave all AC lines connected.
  5. Jul 25, 2023 at 5:03 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    There's room in the drivers side wheel well. Like @TnShooter said, remove the wheel and go through the strut tower.
    Skip to about 2:59 and he'll show you how to get the lower bolts out. Its an earlier Gen2 but it should be the same for you.
    -J
    TnShooter, JGO and DougM_SD[OP] like this.
  6. Jul 25, 2023 at 7:02 AM
    DougM_SD
    Doug
    Lakeside CA
    JustAddMud
    thats actually the best vid ive seen on it... thanks! Im off to try now
    JGO and JustAddMud like this.
  7. Jul 26, 2023 at 7:52 AM
    DougM_SD
    Doug
    Lakeside CA
    Well after 7.5 hrs the truck is done... thanks to any and all who gave advice! appreciated!
