AC Compressor stays engaged
Discussion in '1st Gen. Tacomas (1995-2004)' started by jva8683923, Mar 22, 2012.
  1. Mar 22, 2012 at 3:25 PM
    jva8683923
    jva8683923 [OP] New Member
    Florida
    2004 2WD Tacoma
    Greetings,
    I have a 2004 Tacoma base 2WD Regular Cab. The the AC button on the Control Head stayed illuminated at all times and the Compressor would not shut off. The wiring diagram in All Data showed it being commanded on by what Toyota calls an Amplifier which is attached to the back of the COntrol Head / switch panel . I replaced the Amplifier and the problem has changed.
    With the new Amplifier the AC button shows to turn off (light goes out when depressed) which it did not do before - however - the compressor still runs continous regardless of settings on the COntrol Head. Now im double confused. I also do not have access to a scan tool that will show live data - ie: to see of AC is being commanded on by the ECM.
    Has anyone seen this before -----or any ideas......???? Thanks
  2. Mar 22, 2012 at 3:31 PM
    98tacoma27
    Ben
    Not Beech Creek
    You mean the magnetic clutch is still engaged?
  3. Mar 22, 2012 at 3:43 PM
    jva8683923
    Florida
    2004 2WD Tacoma
    That is correct - the magnetic clutch stays engaged anytime the fan is turned on regardless of button on/off setting and temp setting
    It also does not cycle - it runs continuous anytime the fan / blower is on
  4. Mar 22, 2012 at 4:22 PM
    98tacoma27
    Ben
    Not Beech Creek
    Have you tried unplugging the clutch or testing the voltage at the plug?
  5. Mar 22, 2012 at 5:04 PM
    jva8683923
    Florida
    2004 2WD Tacoma
    I did not unplug the compressor however the compressor does shut off when turning the fan to the "off" postion and back on when the fan/blower is turned on. This shows that it does turn off as it should when the trigger is removed.
  6. Mar 22, 2012 at 5:25 PM
    98tacoma27
    Ben
    Not Beech Creek
    Try turning the AC off and the defroster off.
  7. Apr 8, 2022 at 11:22 PM
    Joselara1997
    Joselara1997 New Member
    Jose
    Truck
    I have the same problem, did you fix it?
  8. Apr 8, 2022 at 11:31 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Yeah copy that. AC compressor turns on when it’s set to defrost.
  9. Apr 9, 2022 at 2:22 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Your AC control relay may be sticking. Place your hand over the relay while someone else actuates and de actuates the AC clutch. You should feel it click on and click off. Your relay should not be latching.
  10. Apr 9, 2022 at 4:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    10 year old thread.
    treyus30 likes this.
  11. Apr 9, 2022 at 9:10 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    That’s a lot of negativity.
    Rumor has it, the issue still persists.
  12. Apr 9, 2022 at 9:27 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I doubt the OP will answer the question posed by @Joselara1997...his only 3 posts were on this thread 10 years ago.
    Diablo169[QUOTED] likes this.
