AC Compressor Won't Turn On After Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scoostraw, Jul 26, 2022.
  1. Jul 26, 2022 at 11:21 AM
    scoostraw
    scoostraw [OP] Well-Known Member
    Ken
    Wisconsin
    1995 Tacoma 4x4 Ext Cab 6cyl 5-Speed
    Hi guys.
    2008 2.7l - my AC died the other day with loud SCREEEEEECH! And the AC button started blinking.
    I went ahead and replaced the compressor. After drawing a vacuum, I tried to charge the system but the compressor is not being commanded on.
    I verified that the pressure switch is closed (zero ohms) and I have about 70 pounds from the R134a on the low side. The AC fuse is not blown. The AC button no longer is flashing g.
    If I jumper 12v directly to the compressor it starts and runs fine.
    Something is preventing the compressor from being commanded on, but I don’t know what - and I don't have a wiring diagram.
    What am I missing here? Any ideas?
  2. Jul 26, 2022 at 11:36 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    :popcorn: Watching
  3. Jul 26, 2022 at 2:29 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    How did you jumper 12V to compressor? Have you check the AC MAG relay?
    TnShooter likes this.
  4. Jul 26, 2022 at 2:30 PM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    Sounds like the relay
  5. Jul 26, 2022 at 2:59 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Did you by chance flush the system? When the compressor goes like that, bad things end up in the lines. If you don't flush them out, the new compressor will clutch its chest pretty quickly.
  6. Jul 28, 2022 at 6:43 AM
    scoostraw
    Ken
    Wisconsin
    Hi guys,
    Thank you for the suggestions.
    I unplugged the high-side pressure switch and jumpered the pins together. The system then turned on normally and all is well - even after plugging the switch back in. The compressor runs very quietly and the system is cooling nicely.
    6 gearT444E likes this.
