AC COOLING
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fixit101, Jul 9, 2020.
  1. Jul 9, 2020 at 4:07 PM
    fixit101
    fixit101 [OP] Member
    mark
    2010 tacoma TRD
    none
    Blowing low volume of air through vents. Blower motor is good. Actuators good. New evaporator new still low volume. Any suggestions out there.
  2. Jul 9, 2020 at 4:09 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    What is "low volume of air"?
    BillsSR5 likes this.
  3. Jul 9, 2020 at 4:13 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  4. Jul 9, 2020 at 4:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check your cabin filter to make sure it's not clogged. Check your resistor plug/ resistor.
    lynyrd3 likes this.
  5. Jul 9, 2020 at 4:19 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    The resistor is fairly new was put in last year. Brand new cabin air filter.
  6. Jul 9, 2020 at 4:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The plug for the resistor is know to have issues.
    Unplug it and look at the connector for an signs of heat damage or melting.
    12TRDTacoma likes this.
  7. Jul 9, 2020 at 4:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Also look at the rear of your HVAC panel. It is known to burn the connections back there.
    TnShooter[QUOTED] likes this.
  8. Jul 9, 2020 at 4:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Does it start off running normal then slow down after a bit of time?
    Or is it low all the time?
  9. Jul 9, 2020 at 4:33 PM
    TnShooter
    Deogee
    STOCK
    I haven’t see that one yet. Thanks for the heads up:thumbsup:
    12TRDTacoma[QUOTED] likes this.
  10. Jul 9, 2020 at 4:36 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    Let me give you the full story. Last month I encountered this lack of air coming from the vents. If you place a paper tissue in front of any of the vents it hardly moves it. The heat and AC work but only a low volume comes out the vent. I ripped the dash apart to replace the evaporator. On the work bench I power up the HVAC unit to check if it was working properly. Everything was running smoothly on the bench, all 3 actuators opened and closed the blends doors, as they should. The blower fan work on all setting, with new cabin filter installed. High volume of air coming from the vents, everything seems fine.When I put the HVAC back in the truck, with all plugs and switches connected I still have the same low air flow coming from the vents. I really need your help and any suggestions.
    PhxRising85 likes this.
  11. Jul 9, 2020 at 4:39 PM
    TnShooter
    Deogee
    STOCK
    Does it do it on Recirculate as well?
  12. Jul 9, 2020 at 4:39 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    No it run as it should. As you increase the speed setting on the switch the fan does the same, the is no slowing down on fan speed.
  13. Jul 9, 2020 at 4:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Ok, but to be sure I'll ask again, since you don't specifically say...........
    Out of curiosity, why did you go after the evaporator replacement? Did you detect a loss of refrigerant at that location?
    TnShooter likes this.
  14. Jul 9, 2020 at 4:40 PM
    TnShooter
    Deogee
    STOCK
    Are you saying the fan speed is the same no matter what position the speed switch is in?
  15. Jul 9, 2020 at 4:41 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    Re circulation works fine you can see the actuators move and the fresh air door move.
  16. Jul 9, 2020 at 4:42 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    I thought the evaporator wad bad.
  17. Jul 9, 2020 at 4:43 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    The fan speed moves in tandem with the setting of the switch
  18. Jul 9, 2020 at 4:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Because of air flow?
    And still, can you answer the question? Trying to help here.....
  19. Jul 9, 2020 at 4:45 PM
    TnShooter
    Deogee
    STOCK
    Is it the same low volume from all vents?
    I ask this because it sounds like there is a restriction some where.
  20. Jul 9, 2020 at 4:46 PM
    fixit101
    mark
    2010 tacoma TRD
    none
    There was no loss of refrigerant as a matter of fact the evaporator was in very good condition, little or no dust.
