AC cycle on and off, 2003 3.4 pre runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by tnt136913, Oct 17, 2014.
  1. Oct 17, 2014 at 5:37 PM
    tnt136913
    tnt136913 [OP] Member
    2003 pre runner 3.4,, my ac will work great then will start to cycle on and off and here a clicking noise under the glove box , is it the thermistor in the evaporator box, ac is charged right, truck only has 50.000 miles, I do have the service manual,
  2. Oct 17, 2014 at 5:44 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    That's normal
  3. Oct 17, 2014 at 5:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Completely normal, unless it is doing it really fast (in which case it may be low on freon (R134A))
  4. Oct 17, 2014 at 5:57 PM
    tnt136913
    but the temp from the ac duct goes from 40 up to 80 when its 90 plus outside, never use to get that hot , ac is fully charged
  5. Oct 17, 2014 at 6:14 PM
    MrGlipsby
    MrGlipsby Active Member
    Steven
    Louisiana
    14 4x4 DC TRD OR MGM
    - Prinsu CabRac - Undercover SE Tonneau - Weathertech Floor Liners
    I used to have a 2004 3.4 Prerunner that had a very similar issue where the blend door under/behind the glove box would open and close several times in a row and it happened fairly often. If I turned the thermostat to hot for a second or two and then back to Cool, it would go away. I just dealt with it. Bad temp sensor is likely.
  6. Oct 17, 2014 at 7:47 PM
    tnt136913
    thanks will see if that works, sure don't want to pull the evaporator box, after looking in service manual it may be the air inlet servomotor
