AC cycling.. 16 OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFister, May 9, 2016.
  1. May 9, 2016 at 12:07 PM
    TacoFister
    TacoFister [OP] Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    So. I wrote a thread on the chirping sound. I still can't get that to stop. Also. Does anyone ac compressor turn off and back on every 10secs? Rims go from 500 to 900 then it turns back off? You can feel it when the truck is in park
  2. May 9, 2016 at 12:29 PM
    TacoFister
    Josh
    Does not do it in Drive
  3. May 9, 2016 at 1:25 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    It will cycle if the cabin as at the desired temp. It does this to keep the evaporator from freezing up. If you turn the fan to MAX, does it take longer for it to cycle? If so, it answers your question. If it continues to cycle, then it may be low on refrigerant.
  4. May 9, 2016 at 1:28 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ... ^^^ ... Mine does that since new ... when in park ... not sure about neutral ... but the tach bounces a lot several times a minute.
  5. May 9, 2016 at 1:33 PM
    TacoFister
    Josh
    I don't have the fancy tech package. I will try it on max. Drive it works fine in any more. Just park
  6. May 9, 2016 at 1:41 PM
    SamChieftan
    SamChieftan Well-Known Member
    Dallas, Texas
    2016 TRD OR AUTO 4x4 Super White
    Interior LEDs, Truck Mat, Door sills
    Yes that is the AC cycling. Mine does the same thing. I do not have the tech package. My AC so far blows really cold; so I know it is working okay.
  7. May 9, 2016 at 2:41 PM
    TacoFister
    Josh
    Same here. Just never noticed it as much as on other cars. My 14 Camry was smooth as butter and it was a 4cyl. On the taco, you can feel it turn off and on.
  8. May 9, 2016 at 3:01 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Mine's the same and to the point where if I'm at a stop light in drive and light on the brake, the truck will actually jump forward a bit. I've learnt to apply a little heavier foot on the brake if either the defrost or AC is on.
  9. May 9, 2016 at 3:06 PM
    Gus Gorilla
    Gus Gorilla Well-Known Member
    2016 White TRD OffRoad
    None...yet
    Cycling compressor is normal. That's how it works. I agree it's not real refined though.
    Some cars use a variable compressor or variable metering valve (varying oriface) but this setup is a "fixed-oriface cycling-compressor" setup.
  10. May 9, 2016 at 3:34 PM
    TacoFister
    Josh
    Speaking latin. Yeah I mean the Rpms jump up to compensate for the load. Never noticed that kind of compinsation on a vehicle before. The 4cyl 170hp or whatever it was didn't even make a noise or felt that the AC was on, it was smooth and as you said refined. Just weird to see Rpms climb to compinsate for a ac compressor load on a 278hp engine.
