Ac defroster fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikedaz, Jan 14, 2009.
  1. Jan 14, 2009 at 1:35 PM
    mikedaz
    mikedaz [OP] Active Member
    NH.
    07 SR5 I4 4x4, access cab, 5 speed,
    bug deflector, vent guards, running boards ,stainless tip,summer + winter tires + wheels,secondary filter removed,60 series delta flowmaster,tow hitch,pop+lock
    That was a great mod,;)with the I 4 engine it would slow the truck down a little when it kicked on from using defrost.:confused: Now if there was a way to shut off that tire pressure light!:cool:
  2. Jan 14, 2009 at 1:38 PM
    DMZX
    DMZX Active Member
    E. Oregon
    2x4 Tacoma
    Check your spare?
  3. Jan 14, 2009 at 4:33 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Remove the bulb
    Ok, Just kidding:D, but...
    It would work.
  4. Jan 14, 2009 at 4:38 PM
    Okkine
    Okkine Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Been meaning to do the defroster mod. Anyone try it on an '09 yet?
  5. Jan 14, 2009 at 4:46 PM
    mikedaz
    NH.
    I have different tires and wheels with no sensers.
  6. Jan 14, 2009 at 5:07 PM
    CtryBoyInMT
    Thats the only 100% positive option I've read about.
    Their have been people claiming on "less than superior forums" than this one, of ways to cut this, weld that, jump on your toes three times, etc. But they only seem to work for a few days then the system "errors out" and causes a continuous flashing annunciator (Way more of a distraction).
    And I don't feel comfortable with a PVC pipe idea with 35Psi of air sitting in my cab. Just an opinion though.:D
  7. Nov 20, 2015 at 1:44 AM
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    how is this mod done? help please.
  8. Nov 20, 2015 at 2:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    You woke up a 6 year old thread and the OP hasn't been here since February.
    Maybe try a PM directly to the OP ?
    Lt_Dan[QUOTED] likes this.
  9. Nov 20, 2015 at 3:04 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  10. Nov 20, 2015 at 4:20 AM
    Lt_Dan
    Daniel
    Cincinnati OH
    I did try searching for the instructions, but there were too many results to look through. I thought the point of this forum was to share information and learn from each other, who cares if i woke up an old thread? The gentleman below provided the link, so that means this method of inquiring worked.
    Thank you very much!
