AC delay after start up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jesse H, Aug 11, 2023.
  1. Aug 11, 2023 at 4:12 PM
    Jesse H
    Jesse H [OP] Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I'll admit this is more of a first world problem type of nit pick but anyone else here find that the delay in the HVAC fan to actually spin up to max speed annoying? This is with the auto climate control.
    This is my first summer with the truck and I never noticed it until we've been having triple temp digits for the past month. Get in the truck, start it up and it's about 10 seconds before the fan climbs up to max speed.
    Ten seconds feels a bit longer when it's probably 130 degrees inside the cab. I've finally trained myself to leave the door open and sit for a moment before the fan actually kicks on. Anyways, is this a Tacoma thing or do all Toyotas do this?
  2. Aug 11, 2023 at 4:17 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Up on the other side of the country, heaters don't heat the best when it's -30 outside.
    Can't imagine A/C perfoming well in triple digits.??
    musicisevil likes this.
  3. Aug 11, 2023 at 4:19 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Mine is similar. I believe it has to do with the computer figuring out what it needs to adjust and then actually adjusting it before activating the fan. Theoretically the settings are left as you had them, but it would still need to make sure that is the case. Plus, the refrigerant needs to start flowing too.
    It is even more dramatic in the winter or cold weather when "auto" mode will wait a while until some heat has built up in the engine before turning on the fan. You can bypass this without using the automatic setting, but you'll still be getting cold air anyway.
  4. Aug 11, 2023 at 4:21 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I put my windows down right away, and drive off letting the heat escape.
  5. Aug 11, 2023 at 4:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    My 14 RAV is same.
    Just hit the fan button which will override the auto stuff.
    Stevie17 likes this.
  6. Aug 11, 2023 at 7:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I think it’s cooling/heating up system, ducts, etc, before making you more uncomfortable by blasting more of what you don’t want. Every vehicle w auto climate I’ve had, has done this.
  7. Aug 11, 2023 at 9:40 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    hmmm, i don't have the auto climate control and i also turn my AC off before i shut the truck off, that being said, when i start my truck i let it idle for 10-15 seconds or so then i turn the AC on, i dont have issues with the fan ramping up, the air doesn't start to get really cool until i get moving but that's normal. I'm also in Phx.
    I'm guessing your issue is related to the auto climate control you mentioned??
  8. Aug 12, 2023 at 1:51 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Normal, and not an issue for me. I leave my system on auto all the time.
    Chew likes this.
  9. Aug 12, 2023 at 8:02 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The reason is mentioned in the manual
    Phlogiston and Chew like this.
  10. Aug 12, 2023 at 9:44 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Geez, there's that pesky owners' manual again :anonymous:
  11. Aug 12, 2023 at 12:19 PM
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    Good info, thanks!
    The heater taking minutes before the blower kicks on makes sense since the heater core takes a while for things to warm up. Interesting about the AC.
  12. Aug 12, 2023 at 1:40 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    50% of the discussions here wouldn’t even take place if the manual was read by more peps
    ktbell444[QUOTED] likes this.
  13. Aug 12, 2023 at 7:55 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    To be fair, I did assume @Chew's answer was the correct one until I went digging. Honestly, what he said makes more sense to me than odor control.
    Chew likes this.
  14. Apr 11, 2025 at 2:57 PM
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    I got Carista for a week to disable the seatbelt chime on my wife's new Lexus this past fall. Hooked it up to the Tacoma to see if there were any settings I was interested in and found one for the fan delay so I changed it. Didn't notice a significant change since we haven't had warm weather until this week.
    Finally, hop in a hot truck and it no longer takes 10 seconds for the fan to reach max speed.
  15. Apr 11, 2025 at 3:07 PM
    Williston
    Williston Unknown Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    I have had four vehicles with automatic climate control and all of them gradually brought the fan up to speed. If it was really hot (windows closed all day) in "auto" they would start in recirc mode unless you over-rode it, and bring the fan up to full speed fairly quickly. Cold out/winter: slower gradual increase as the engine temp came up, or full-blast almost immediately if defrost/de-ice was selected.
