AC Diagnostic Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elvota, May 29, 2019.
  1. Jul 1, 2019 at 12:38 PM
    #41
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
  2. Jul 1, 2019 at 12:52 PM
    #42
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    If the freon is a little low, the comp will cycle on and off before the cab cools down. If the ambient temp is warm.
    Leaks do indeed lose a little oil, but how do you know how much oil is lost? Guessing how much to add is not good. Too bad they don't have a dipstick like the old York/Tecumseh compressors. Those old systems also had more oil and ~5 pounds of R12. 21oz is a bit more of a critical charge.
  3. Jul 1, 2019 at 12:54 PM
    #43
    Elvota
    Elvota [OP] Well-Known Member
    2006 Tacoma TRD
    Yeah... I am leaning towards that. To much or too little refrigerant might cause the issue I am having?
    System did hold a vacuum and i am fairly sure no leaks... but i appreciate the heads up.
  4. Jul 1, 2019 at 12:58 PM
    #44
    mgord
    mgord Well-Known Member
    Harrisburg, PA
    07 TRD
    K&N, Leaf Springs, Home Built Camper
    How about popping off the clutch plate on the AC compressor and removing a shim? I've done this a couple of times with the Subaru's I have and that seemed to kick off the compressor.
  5. Jul 1, 2019 at 12:59 PM
    #45
    Elvota
    2006 Tacoma TRD
    I really wasnt trying to guess oil level.
    I drained new compressor, added 150cc per FSM, cycled by hand and then installed.
    I guess my measuring the old compressor oil one understands how much oil is left in the system... thus preventing to much oil.
    Would to much oil cause the issue I am having? How critical is the oil level?
  6. Jul 1, 2019 at 1:16 PM
    #46
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    150cc = 5oz. I don't remember the exact oil capacity for this system. The tag on my truck is MIA. What is the total system capacity, anyone?
    Elvota[OP] likes this.
  7. Jul 1, 2019 at 1:30 PM
    #47
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    Im in this same situation on a 2002 impala , the GM uses an Orifice tube, I was getting same readings as the ops. Turns out the compressor is toast so rock Auto for 80% new parts for 380$ You must flush your system!!!!
  8. Jul 1, 2019 at 1:54 PM
    #48
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Haha, them days are over though
    The compressor might be short cycling, cant remember if OP said he heard it doing that. Too much oil can keep good heat exhange from occurring at the condensor.. lots of variables in these situations where you're trying to DIY
    IwasDacapsterAz likes this.
  9. Jul 1, 2019 at 2:01 PM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Alldata says 5.1 fl oz
  10. Jul 1, 2019 at 2:29 PM
    #50
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    As far as oil level... all the compressors I remember doing said to drain the old one into a measuring device, and add the greater of 3oz or what you got out of the old one... never once do I recall getting more than the 3oz out of the old one.
    As far as getting warm at idle, it seems to just be a thing with this truck and the mechanical fan. If a vehicle has a more sensitive fan clutch or a more overkill condenser, it can make it less prone to happening, and if you've got the charge low you can exacerbate the issue, but from what I've heard here, it is to some extent going to happen.
    I put an electric Flexalite on mine (mostly for the MPGs), you could also add an electric fan in front of the compressor, there's plenty of room. Either way, more airflow when sitting so as to not heat soak the condenser is the key.
  11. Jul 1, 2019 at 3:30 PM
    #51
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yep, long gone.
    Too much oil does that, and more. Extra oil displaces capacity for freon.
    b_r_o[QUOTED] and Elvota[OP] like this.
  12. Jul 1, 2019 at 3:34 PM
    #52
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    If the condenser wasn't replaced, which holds the filter drier, and the rest of the system wasn't flushed, there is too much oil in the system.
  13. Jul 2, 2019 at 9:18 AM
    #53
    Taco'09
    Taco'09 Well-Known Member
    OP, I'm thinking you have way too much oil now in the system and here is why.
    At the factory, all the other pieces of the A/C system are installed in place dry and the compressor is the last piece. No oil is placed in any of the other components except the compressor. A new compressor comes with that amount of oil (150cc) and that amount is intended to to be dispersed to the entire system.
    The system is charged with R134A and engine is finally started and the compressor engaged. That oil in the new compressor then is circulated along with the refrigerant and some accumulates in the condenser, some in the evaporator, some in the hoses and misc. components and the remainder in the compressor.
    IMHO the FSM is very confusing and could easily lead one to think that 150cc should be added whenever a new compressor is added. It is not. The best the FSM does is to give one an idea of how much new oil is added to the system when a single failed component is replaced. That is why you must think of balancing the oil in the compressor separate from adding more to one or more failed components.
    CurtB and Elvota[QUOTED][OP] like this.
  14. Jul 2, 2019 at 10:16 AM
    #54
    Elvota
    2006 Tacoma TRD
    I agree... from your suggestion and others.
    My new plan is to replace the condensor as there is a good chance it might be clogged or damaged from previous compressor failure. At that time I will also clean out all the lines.
    I think that should bring the 150cc oil level far closer to what the system needs.
    But... I wont have time to deal with all that for a bit...
  15. Oct 28, 2020 at 7:55 AM
    #55
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    Reviving your post here. How did you find that the ground was bad? Was it just loose or something? I'm trying to run down the blinking light problem w/o taking to a shop if possible.
  16. Oct 28, 2020 at 12:00 PM
    #56
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I could see that it was frayed
    Mcdees84[QUOTED] likes this.
  17. Nov 2, 2020 at 6:25 AM
    #57
    Mcdees84
    Tallahassee, FL
    Thanks.
  18. Nov 20, 2020 at 6:57 AM
    #58
    Spindifferent
    Spindifferent Well-Known Member
    Central Texas
    2013 PreRunner 4.0 v6
    OP - were you able to fix the issue? I've got the blinking AC light on my 2013 and am wondering how to fix it.
  19. Dec 9, 2020 at 3:20 PM
    #59
    Elvota
    2006 Tacoma TRD
    Turned out my compressor was bad... all electrical controls and wires were OK.
    Spindifferent[QUOTED] likes this.
