AC different out of each vent
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IFeelfishy, Jul 13, 2022.
  1. Jul 13, 2022 at 2:18 PM
    IFeelfishy
    IFeelfishy [OP] Well-Known Member
    2011 Tacoma
    I might need an AC re-charge, but before I do that I wanted to get a response from people who know better than I. I have noticed that my AC in my 2011 tacoma is not really cooling off the cab. The air coming out of the most drivers side vent is nice and chilly. I have the setting on just blowing on the face, not the floor or the glass. However, the air coming out of the Drivers right side is a little warmer, and the air coming out of the passenger's left side is even warmer than that. Finally the most passenger side vent is blowing hot air (easy 15-20+ degrees hotter than the most driver's side vent). I am not sure if it is related or not, but when I turn the truck off after the AC has been blowing for a few minutes the AC compressor making a lot of noise for a few minutes. I am sure someone on here knows more than I do, does this sound like something an AC re-charge can fix, or something different within the AC system?
  2. Jul 13, 2022 at 4:33 PM
    dblwall
    dblwall Active Member
    Az
    2012 TRD Sport
    I had the exact same symptoms, took it to a trusted shop since I know little about AC. Had a pin hole in the refrigerant discharge hose. Replaced, recharged and good to go.
    Somewhere you have a leak.
    IFeelfishy[OP] likes this.
  3. Jul 13, 2022 at 4:38 PM
    Bishop84
    Bishop84 Well-Known Member
    Low charge causes this.
  4. Jul 13, 2022 at 5:05 PM
    DDRD
    DDRD Member
    2012 Tacoma
    2012 prerunner, Same problem. Cold air on driver's side vents warm air on passenger vents. It's been working fine all vents for five years. Seems strange that driver's side is cold and would need refrigerant.
  5. Jul 13, 2022 at 5:06 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    this can happen from low freon or a temp door actuator that is not moving the temp door, or the temp door itself is stuck.
    wi_taco and IFeelfishy[OP] like this.
  6. Jul 14, 2022 at 11:54 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I also had the cold on the left side vent and gradually gets warmer as you move to the right passenger side vent.
    It was low R134A Charge due to a leak. Replaced HP Line and Condenser / Dryer and recharged. Has been good for many years since.
    TnShooter likes this.
