AC-DK 13500 LB Winch Mounting
Discussion in 'Recovery' started by Fanatic45, Dec 19, 2021.
  1. Dec 19, 2021 at 10:49 AM
    Fanatic45
    Fanatic45 [OP] New Member
    2021 Cement Tacoma Trail
    Hey, recently acquired a 13500 LB winch and was just looking for some advice or tips/ tricks for not fucking myself over mounting.
    I have a 2021 Trail edition and wanted to do a rear mount or semi hidden front mount due to the size of the winch.
    I’m hesitant to purchase a mount due to the size of the winch and if anyones had any bad experiences or just general advice for it. Also not trying to get a big steel bumper and have it rust out in 3 years and get new suspension.
    https://www.amazon.ca/hz/intuition/...c0&ref_=pd_gwm_pd_aw_di_ci_int_sci_gw_atf_m_1
  2. Dec 19, 2021 at 10:57 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Where do you live that steel bumpers rust out? Second, if you think the bumper will rust out first you're in for a huge dissapointment when your frame is gone 5 years before the bumper even has a hole haha. That said look at US Off-road for a stock bumper winch mount.
  3. Dec 19, 2021 at 10:59 AM
    Fanatic45
    Southern Ontario where they salt the roads at 3 degrees out. I’ve got the frame covered with fluid flim and I’ll come up with a more permanent solution next year.
  4. Dec 19, 2021 at 11:04 AM
    Speedytech7
    Yikes, well I wish you the best of luck in that endeavor. I hear Krown does wonders for Toyotas since they're basically rust magnets.
    Fanatic45[QUOTED][OP] likes this.
  5. Dec 21, 2021 at 11:29 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I don't see anyway around that,between the winch itself and it stated it requires two 12 volt batteries.
