Ac drain line causing rust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Aug 14, 2011.
  1. Aug 14, 2011 at 9:46 AM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    Anyone have rust on their frame rail caused by the ac condensate drain line?
  2. Aug 14, 2011 at 9:57 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Nope:). AZ FTW!!! rust is basically non existent in the desert.
  3. Aug 14, 2011 at 11:27 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Recently there was a post about this. Ultimately the guy, or girl, located the drain and extended it.
    Seemed feasible, I used a plastic 90 degree fitting and short section of tube and now mine is dumping below the frame rail, inside the right wheelwell.
    With it not hitting the frame to dissipate, it is quite a bit of water with the humidity here in South Florida.
    PK
  4. Aug 14, 2011 at 11:28 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    What is this, pre-emtive worrying? I wouldn't "sweat" it, no pun intended.
  5. Aug 14, 2011 at 1:34 PM
    PMK
    Florida
    10 DCLB TRD Sport
    Careful cowboy...seems you convinced some of us to ground our throttle body.
    Seriously, FWIW, my 2010 has marks on the frame already from the constant water draining onto it.
    Probably it's a very good idea to do something about this.
    Inexpensive, easy to accomplish, no real performance gain, but does do something to help the truck last.
    PK
  6. Aug 14, 2011 at 1:38 PM
    myname150
    myname150 Well-Known Member
    Yeah maybe just buy some cheap small rubber hose attach it to the end and clamp it to the drain.
  7. Aug 14, 2011 at 9:25 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    What's rust? ;)
  8. Jun 5, 2015 at 11:30 AM
    skrazz
    skrazz 2013 SR5 4x4 4.0L AC
    St. Petersburg
    Found this thread in the quest of answers given my own "AC drain/rust" situation. My 2013 seems to have developed some surface rust due to this issue. When things cool off, I'll be doing the reroute mod. Dealer couldn't do anything for the drip or areas with rust so once I've got the new tube in and everything's dry, I'll be sanding and spraying down all the trouble spots. This was taken at the passenger side right under the door.[​IMG]
  9. Jun 5, 2015 at 11:41 AM
    patbegley
    patbegley patbegley.com
    Vancouver, BC
    '15 DCLB
  10. Jun 5, 2015 at 1:15 PM
    The109
    The109 Well-Known Member
    Joe
    Moab, Utah
    2013 TRD Access Cab
    I cut a length of old garden hose and clamped it to the drain spiggot/cock/whatever. While in Moab my friend looked under the truck and said, "Dude you got a effin hose coming out the bottom of your truck!"
    patbegley likes this.
  11. Jun 5, 2015 at 1:58 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    '15 Tacoma PreRunner V6 SR5 Auto
  12. Jun 6, 2015 at 3:23 PM
    skrazz
    St. Petersburg
    Thanks for the input y'all. I went with the 5/8" inner diameter tubing with a hose clamp going straight down. I'm slightly concerned by the added weight on the original tubing so I'll check it frequently. Here are some shots:
    It might be necessary for me to put a little spacer between the frame and my new drain tube given that I only asked for a foot. I'll be testing it out in the next few minutes.
    edit: It works.
  13. Jun 6, 2015 at 11:37 PM
    20Tacoma14
    20Tacoma14 Member
    CA
    14 4x4
    is that a wasps nest?
    SigSense and skrazz like this.
  14. Jun 7, 2015 at 8:05 AM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    Looks like a paper wasp nest.
  15. Jun 7, 2015 at 8:56 AM
    skrazz
    St. Petersburg
    Yeah, nobody wanted an SR5 4x4 but me and some wasps so it sat on the lot for a few
