Ac evaporator doesn’t drip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Mar 15, 2018.
  1. Mar 30, 2018 at 10:01 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Still haven’t fixed this
    Been hot here and running the ac 24/7. Still zero dripping and the ac is working well enough
  2. Mar 30, 2018 at 10:07 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Have you blown compressed air in the drip tube? You may have a restriction in the drip tube. I’ve seen everything from mold, dead bugs, mud, and a fire ants nest inside hvac housings blocking drip tubes.
  3. Mar 30, 2018 at 10:20 PM
    anthony250f
    Anthony
    San Diego, CA
    I have not. I don’t have a compressor.
    I did remove the the drain tube and stuck an object nearly all the way into the tube. Also I can very easily blow into the drain tube. I also feel a cool breeze coming out of the drain.
  4. Mar 30, 2018 at 10:22 PM
    Bebop
    Nick
    Sticking things in the drain tube is not recommended. The evap core won’t sweat and drip if the humidity is low.
  5. Mar 30, 2018 at 10:26 PM
    anthony250f
    Anthony
    San Diego, CA
    I didn’t stick it into the evaporator. I only stuck it into the drain tube. Just far enough to go to the sharp left hand turn into the housing. I will try compressed air in a can but I really do not think it’s clogged.
    Humidity is 80-90% so it should be dripping
  6. Mar 30, 2018 at 10:31 PM
    Bebop
    Nick
    Is it just dripping slowly or not at all?
  7. Mar 30, 2018 at 10:32 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Is your AC blowing really cold air like it should? It might just need to have the system charged. You just can't swap out compressors without the vacuum equipment to suck it down and evacuate the system.
  8. Mar 30, 2018 at 10:36 PM
    anthony250f
    Anthony
    San Diego, CA
    Nothing at all
  9. Mar 30, 2018 at 10:37 PM
    anthony250f
    Anthony
    San Diego, CA
    No it’s not that cold, but it’s not terrible either. I’ve swapped out compressors before and have used the manifold gauges and vacuum pumps. Luckily autozone rents them for free. Had to do it twice on my 1st gen.
  10. Mar 30, 2018 at 10:56 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    There is an over the counter evaporator cleaner that might be worth a shot. Sounds like you're low on charge though.
  11. Mar 31, 2018 at 1:22 PM
    anthony250f
    Anthony
    San Diego, CA
    Well it was about 90 % humidity today and the drain hose was dripping pretty good.
    Drainbung and b_r_o like this.
  12. Mar 31, 2018 at 1:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you get the compressor in there?
    anthony250f[OP] likes this.
  13. Mar 31, 2018 at 2:09 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Inquiring minds want to know...
  14. Mar 31, 2018 at 2:36 PM
    anthony250f
    Anthony
    San Diego, CA
    Nope have not installed the new compressor lol.
    I will likely do it this summer. Just don’t really have the time for it now. Maybe if I get a spare weekend when I’m up for it.
    It was dripping pretty good, left a puddle under the truck.
    Drainbung likes this.
  15. Mar 31, 2018 at 2:41 PM
    #35
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    If the compressor was toast you'd know it. I still think you're low on charge. I'm not sure about the quality of the the vacuum pumps that the shops loan out. I did a lot of work on aircraft pods and we would leave them on vacuum overnight before even thinking about charging the system.
  16. Mar 31, 2018 at 2:54 PM
    #36
    anthony250f
    Anthony
    San Diego, CA
    The compressor works but it’s starting to make noise. Wanted to change it out before a catastrophic failure.
    I too think it’s low on charge.
    The vacuum worked pretty good. Got it to -30 mercury which is perfect and then had it run for a few hours.
  17. Mar 31, 2018 at 2:55 PM
    #37
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Might just be the clutch going out. I had that happen on another truck (non-toyota). Just a thought.
  18. Mar 31, 2018 at 3:01 PM
    #38
    anthony250f
    Anthony
    San Diego, CA
    I hoped that it was but unfortunately it’s not. The noise only occurrs when the clutch engages, but it is a rattling sound (video on page 1) I removed the belt and the pulley spins fine and free.
  19. Mar 31, 2018 at 4:40 PM
    #39
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Well that certainly narrows it down. I would have thought the compressor would have lasted longer than that.
  20. Mar 31, 2018 at 4:44 PM
    #40
    anthony250f
    Anthony
    San Diego, CA
    I have almost 200k! Haha
    Drainbung[QUOTED] likes this.
