Ac evaporator doesn’t drip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Mar 15, 2018.
  1. Apr 22, 2018 at 3:39 PM
    #41
    trdmikey8
    trdmikey8 Well-Known Member
    2016 Tacoma TRD Sport
    Snugtop Camper Shell
    I also have the same issue on my 3rd gen. It was working fine before and now it won't drop. Ac is blowing cold air and talked to the dealer but they said it is fine since it's still blowing cold air.
  2. Apr 22, 2018 at 8:59 PM
    #42
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Speaking of AC dripping... your drain tube under the truck drips directly onto the frame of the truck. Which over time is gonna equal lots of rust. You can buy a brass dual male hose connection and add about 5 inches of hose and have it drip onto the ground. Save your frame a little. Just FYI
  3. Apr 22, 2018 at 9:04 PM
    #43
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Was planning on getting around to that.
    There’s zero rust on this frame though even in the ac drip area
  4. Apr 22, 2018 at 9:07 PM
    #44
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    How do you have an '08 in SD with no rust....
  5. Apr 16, 2019 at 2:36 PM
    #45
    Tacomax4
    Tacomax4 Well-Known Member
    2012 DCLB TRD Sport 4x4
    I’ve got no drips either... just the cool breeze coming out of the AC drain tube. No water on the passenger floor and good cooling through the vents. Should I be concerned?
    b_r_o likes this.
  6. Apr 16, 2019 at 2:44 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Depends.. how warm is it where you're at?
    With the system running, pop the hood and check for condensation on the ac lines. If they're dripping wet out in the engine bay then the evaporator should be dripping in the dash.
    Tacomax4[QUOTED] likes this.
  7. Apr 16, 2019 at 2:50 PM
    #47
    anthony250f
    Anthony
    San Diego, CA
    luck? lol the frame has zero rust luckily.
  8. Apr 16, 2019 at 3:03 PM
    #48
    Tacomax4
    It’s 17C. I’ll check that thanks
    b_r_o[QUOTED] likes this.
  9. Feb 23, 2024 at 10:02 AM
    #49
    Toolgirl
    Toolgirl Member
    My AC works great but not dripping on the ground under my truck and my driver side floor carpet is slightly wet on and off it drys when it sets and the floor mat is not in it but when I drive it I noticed that it was damp again.
  10. Feb 23, 2024 at 12:02 PM
    #50
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Drip tube is plugged or disconnected under the dash.
