AC Evaporator Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hgiljr, Aug 31, 2023.
  1. Sep 1, 2023 at 8:34 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like the discharge hose is leaking then, the dots on the compressor could be spatter or corrosion which will also kinda glow under UV.
    Did you also look at the A/C drain?
  2. Sep 1, 2023 at 8:44 AM
    hgiljr
    hgiljr [OP] Well-Known Member
    Actually by the discharge hose comment I was referring to the A/C drain on the passenger side and it did have dye. I had a feeling about the spatter onto the compressor. Currently taking apart the dash... I will tackle the evaporator first and see after I recharge about the compressor.
    Dm93[QUOTED] likes this.
  3. Sep 1, 2023 at 10:11 AM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    While TXV's do fail, they rarely leak. Evap is MUCH more likely, as is the o-ring that is in the evap to line connection. Spatter by the compressor could be oil. Most oils will glow under UV light. Put a little dye near the dots and compare. The dye is much brighter than the oil. Freon leaks that take a week to bleed down will not create spatter. Attaching a gauge set to the shrader valves will do this though so if one of the ports is near the compressor that could explain it.
  4. Sep 1, 2023 at 10:53 AM
    hgiljr
    I can't get the crash bar out. What am I missing? I have looked all over and can't find a bolt that is holding it down. I try to move it and it also moves the evaporator/cabin filter box, but can't get the bar out. Any recommendations where to look?
  5. Sep 1, 2023 at 12:39 PM
    hgiljr
    Got her out. It was a clip on the cabin filter case that was holding me back. Oh and I had not fully removed the steering column. Look at the leaks on it.
    Leomania, JAGCanada and wayupnort like this.
  6. Sep 1, 2023 at 1:11 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Dang, I hope that doesn’t happen to my 15. How many hrs. do you have in it at this point?
  7. Sep 1, 2023 at 1:16 PM
    hgiljr
    I would say 4 hours. I could have had it out sooner, but the roadblock of not disengaging the steering column completely and the hidden clip holding the bar to the cabin filter housing. Now just sitting around waiting for Fedex to deliver the parts ordered from Autozone. Should have arrived by 2pm est, now they say 8pm. SMH
    TK-2014 and spitdog like this.
  8. Sep 1, 2023 at 2:05 PM
    spitdog
    I’m surprised how old it looks in the first pic, looks like it came out of a much older truck.
  9. Sep 1, 2023 at 2:13 PM
    hgiljr
    I know. It looks beat up. Truck only has 70k and have owned it since day one.
  10. Sep 2, 2023 at 5:39 AM
    hgiljr
    Good morning. Trying to get the steering wheel shaft back into place but can’t get it aligned. Pardon not knowing the name of the universal adapter, but if anyone has some suggestions let me know. Thanks
  11. Sep 2, 2023 at 7:03 AM
    spitdog
  12. Sep 2, 2023 at 11:54 AM
    hgiljr
    Thanks. I did just that.
    So i have everything back together. Charging it now but seems I forgot something even though I took my time putting it together. First thing I’m noticing is that the fan is set to high and I hear it inside blowing high, but very little air coming through the vents. Interesting enough, I remove the cabin filter and the air flows just fine though the upper vents.
    Also the air direction knob is not working. It’s connected in the back but does not direct air to whichever setting I put it to. Any suggestions?
    thanks again all for your help.
  13. Sep 2, 2023 at 12:55 PM
    spitdog
    My only suggestion is check for blown fuse. Unless it’s mechanical type of function I guess.
  14. Sep 2, 2023 at 1:01 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you plug the actuators all back in?
    https://www.tacomaworld.com/threads/2nd-gen-information-diagnostics.784008/#post-28042158
  15. Sep 2, 2023 at 1:23 PM
    #35
    Pittsy
    Pittsy Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 20 DCSB PRO 6MT
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Sounds like you forgot to plug a servo in or you have the servo linkages in the wrong slots.
  16. Sep 2, 2023 at 1:27 PM
    #36
    hgiljr
    Yeah. It’s the servo in wrong slots. Anyone have a diagram of how the servo cover is to go?
  17. Sep 2, 2023 at 1:35 PM
    #37
    Pittsy
    Davis
    Cave Creek, AZ
    Here's the pics I took from when I took my servos off to change the evap in May. I pulled the linkages directly off and left everything in place.
    Dm93 and hgiljr[OP] like this.
  18. Sep 2, 2023 at 2:46 PM
    #38
    hgiljr
    Thank you. This helped me align it correctly. All working now.
    Dm93 likes this.
  19. Sep 2, 2023 at 2:52 PM
    #39
    hgiljr
    As for a recap for anyone wanting to do this, it can be done but pack your patience and have all the proper tools. My biggest delay was the steering wheel which I had to remove the intermediate shaft completely and snap it back into place. Then the damn servo was a pain to fix as it’s a tight space.
    As for the recharge, I have an internal cabin temperature of 50 degree. I read up on this and for the external temperature in sfla, internal temp should be around this. The low side PSI with fan control in second speed was 30 psi. It wouldn’t accept any more Freon even if I tried. First time doing a recharge so I thought it would continue accepting Freon until one stops it. If I’m incorrect in this assumption or if the PSI should be higher, let me know.
    Again thank you for all your help.
  20. Sep 2, 2023 at 2:52 PM
    #40
    Pittsy
    Davis
    Cave Creek, AZ
    Sweet.
