AC Fan doesn't blow!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06 Tacoma1988, Aug 4, 2009.
  1. Aug 4, 2009 at 7:27 PM
    06 Tacoma1988
    06 Tacoma1988 [OP] New Member
    Hialeah, FL
    06 Prerunner SR5
    H.I.D's, Hood Scoop
    ok my dad has a 07 Tacoma Prerunner and his AC blower doesn't work like the inside fan won't turn on. So i took it apart and it works when i push the fan but then when i turn the AC off and then back on it won't turn on any ideas?
  2. Aug 4, 2009 at 7:29 PM
    Navigator
    Navigator Well-Known Member
    Ontario, Canada
    05 DC Sport 6spd
    17" American Racing Assaults on 265/70/17 Goodyear AT/S, TRD Exhaust, TRD CAI, Toyota Roof Rack, XM install with antenna out 3rd brake light, Red LED Map Lights, AUX Amber LED rocker switch for LED footwell lights, LUND Bug Screen, EXTANG Tri-Fold Tonneau, Hertz Component Speakers w/ TacoTunes Mounts, Infinity Kappa 4 amp, Image Dynamics 10" sub in TacoTunes enclosure, Pop n' Lock, Toyota Aluminum Wedge Running Boards, BHLM, Self Performed '05 Cowl Leak TSB, E-Z Cool Insulation/Sound Deadener applied to floorboard, headliner, and cab bulkhead, 896 Foglight bulbs as backup lights, Weathertechs, Pioneer Double Din, Scan Gauge, AutoSoft Remote Start, 2010 4Runner Heated/Signal/Puddle Mirrors.
    Pull it out and blow out the brushes in the fan with compressed air...this may give it a little more life. If that doesn't work then you need a new blower motor!
  3. Aug 4, 2009 at 7:32 PM
    06 Tacoma1988
    Hialeah, FL
    06 Prerunner SR5
    H.I.D's, Hood Scoop
    OK thanks man
  4. Aug 5, 2009 at 4:51 AM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Get a cheap multimeter and check power (12vdc) and continuity to ground at the connector going to the blower motor first.
    Having basic electrical troubleshooting skills will save you much money as shotgunning an electrical part can cost you money. Most electrical parts are not returnable.
