AC guys please help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tah-koh-mah, May 17, 2020.
  1. May 18, 2020 at 8:09 AM
    Muddinfun
    Muddinfun Well-Known Member
    I’ve rebuilt just about every part of various cars and trucks, but there’s 3 things I leave to the pros. Automatic transmission stuff, body and paint, and AC recharging stuff.
    Jimmyh, BillsSR5 and TegoTaco like this.
  2. May 18, 2020 at 8:35 AM
    jsi
    jsi Well-Known Member
    native earthling
    This is about the only good reason I can think of to suggest taking it to a shop
    OP - AC isn't rocket science. I bought a vacuum pump and pressure gauge set when the "professional" AC places couldn't figure out why the cooler in my wife's car wouldn't hold a charge. Three different shops, three full charges of r134a lost, hundreds of dollars wasted. You can guesstimate how much you need to add buy putting a bit of r134a in and watching the gauges until they get into the published pressure ranges.
    I'll bet a dollar there's a leak somewhere. Putting more r134a in will get the cooler working again, but only temporarily. One last thing, and this is important, DO NOT PUT ANY TYPE OF STOP LEAK IN THE SYSTEM!
    wilcam47, Jimmyh and Tah-koh-mah[OP] like this.
  3. May 18, 2020 at 9:22 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Hell yeah! ;)
    And if I could figure out how to post a PDF from my pc to here I would. I am not a smart man. :(
    You're compressor should shut off when the low side drops below ~28 psi. Obviously it is not. The pressure switch is in the liquid line (line from condenser to TXV.) It is possible that you have a blockage at the TXV or the filter screen just ahead of the TXV.
    I would pull the charge, check that screen, pull a vacuum, then weigh in 22oz of freon. What are the gauge pressures now?
    The pressures you posted are not the same as a system that is just low on freon.
  4. May 18, 2020 at 9:26 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    ^^ this
  5. May 18, 2020 at 9:59 AM
    Tah-koh-mah
    Tah-koh-mah [OP] Well-Known Member
    2012 Tacoma TRD-Off Road
    @DBiffle was your pressure dipping into the negatives under throttle? That's what surprised me.
  6. May 18, 2020 at 10:03 AM
    Tah-koh-mah
    Thanks @CurtB I was hoping you'd chime in. I'll do exactly what you said. Evacuate the refrigerant, pull out the screen and check, pull a vacuum and recharge then take another reading. Just gotta wait for the weather to warm up a bit to recharge.
    Is there a way to check if the expansion valve is stuck closed or partially stuck?
  7. May 18, 2020 at 10:09 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Cant really check the expansion valve until you're sure its got the proper charge amount in it.
    If the system was full and the expansion valve was stuck closed you'd have a hell of a lot more high side pressure, like up over 300 psi
    Your readings indicate an empty system
  8. May 18, 2020 at 10:10 AM
    Tah-koh-mah
    @Clearwater Bill which line going into the evap is the incoming line? The big diameter or the smaller diameter line?
  9. May 18, 2020 at 10:11 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The small one
  10. May 18, 2020 at 10:13 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't disassemble anything yet, charge it and see where you're at
  11. May 18, 2020 at 10:17 AM
    Tah-koh-mah
    Thanks bro, no pun intended.
    b_r_o[QUOTED] likes this.
  12. May 18, 2020 at 10:53 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    You have the gauges so follow the chrisfix video and throw some r134a in there. Make sure you buy pure r134, absolutely nothing with stop leak in it. It’s much cheaper to replace the leaking part and or o rings than the issues the stop leak can cause in the future.
    Only advice is make sure you have a vacuum pump if you plan on opening the system so you can get any moisture out.
    Also before you open the system take it to a shop to have them recover any refrigerant in the system.
    Once you have charged the system to test for a bad expansion valve run the ac system and make sure the compressor cycles on. Then shut the vehicle off and watch the gauges. They should slowly return to the same pressure. It may take 5 minutes or so. If it’s taking longer you may have an issue with the expansion valve.
    Some people over complicate ac systems. It’s very simple and the only thing most DIYers should worry about when doing them is getting the system evac’d with out venting the r134 to the atmosphere.
    Tah-koh-mah[OP] likes this.
  13. May 18, 2020 at 11:05 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yes, after you have the correct amount of freon in the system.
  14. May 18, 2020 at 11:08 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    But, why isn't the low pressure switch cutting out the compressor? Possibly a bad switch and low on freon?
  15. May 18, 2020 at 11:13 AM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I used the term "empty" in a general sense. Undercharged is a better word
    wilcam47 likes this.
  16. May 18, 2020 at 11:31 AM
    #36
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yes, I know what you meant. My point is why the LP didn't work. I have a theory :eek: If the screen is clogged, or the TXV is not opening, there is pressure up to the blockage. The LP/HP switch is one unit, in the liquid line, before the screen and TXV. This would keep the LP from cutting out.
    So empty the system, add 22oz, and read the gauges. Then you will know if there is a blockage. That is where I would start, and I would check that screen while the system is empty. And use new O-rings.
  17. May 18, 2020 at 11:37 AM
    #37
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Also oil the new o rings with compressor oil. If you don’t do it then don’t be surprised when they leak. Ask me how I know.
  18. May 18, 2020 at 11:46 AM
    #38
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I hear ya, but he would have a lot more than 75 psi on the high side if there was a blockage.
    He had 75 psi engine off and 75 psi engine running. If there was a blockage that 75 would have to go up
    In my world, ac diagnosis always begins with verifying the correct charge amount is in the system. Thats hard to do without proper equipment. You can spend a lot of time fiddling around with a system if you dont know how much refrigerant is in there. Simply hooking up the gauges and looking at static pressure isnt enough info. It could read around ambient temp with a full charge.. it could also read around ambient temp with a very low charge..
    I agree the LP switch could be a factor, but need to start with the charge amount..
  19. May 18, 2020 at 12:04 PM
    #39
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Yup. Years ago I was in a hurry ( I was completely stupid) and just hooked up the low side and started charging by pressure. No scales, no nothing. The sight glass had bubbles tho. When the high side hose blew, it got very exciting.
    <Idiot
    Jimmyh and b_r_o[QUOTED] like this.
  20. May 18, 2020 at 3:59 PM
    #40
    DBiffle
    DBiffle Member
    Yes, scared me when I first seen it.
