AC / Heater blower went KAPOOT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Peabo, Feb 5, 2011.
  1. Feb 5, 2011 at 5:03 PM
    Peabo
    Peabo [OP] Member
    Northwest Arkansas
    2005 PreRunner V6
    For whatever reason, I wanted some fresh air, and the fan speed switch does not respond at any speed on any setting (defrost, low or upper vent with AC on or off). Is there a fuse or relay? If so where might I find this important part?
    Thanks very much!
    Peabo.
  2. Feb 5, 2011 at 5:15 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    There are some fuses under the steering wheel behind the change holder and some more on the drivers side under the hood. I'm not sure where the fuse for the fan is but there should be a diagram at each fuse box.
  3. Mar 9, 2011 at 12:43 PM
    FTB530
    FTB530 Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    More then likley its your fan resistor,do a search on here for resistor
    I have changed mine three times and the blwoer mortor and still having problems , i think toyota has a defect some where in this system
  4. Mar 9, 2011 at 12:53 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Not likely the resistor as the resistor is bypassed for the High fan setting. I don't believe there are any fuses for this behind the coin tray. But there are heater fuses in the engine bay. The diagram is on the inside of the lid, but here's a pic anyway:
  5. Mar 9, 2011 at 1:18 PM
    Peabo
    Peabo [OP] Member
    Northwest Arkansas
    2005 PreRunner V6
    As it turned out, it was the blower itself. I was lucky enough to find one and have a freind send to me. The dealer here in Arkansas advised that there are issues with the blowers that are being made in Nam, and they are on national back-order. some have been waiting for 3 months for one. They are very easy to replace - about a 20 minute job.
    Appreciate you!
  6. Mar 9, 2011 at 1:31 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    A 3 week delay for my replacement.
  7. Mar 9, 2011 at 2:09 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    TN
    '13 Black DCSB Sport 4x4
    ¯\_(ツ)_/¯
    i waited about 3 weeks for my new one.
  8. Mar 16, 2011 at 9:10 AM
    kbp68
    kbp68 hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
  9. Mar 16, 2011 at 10:14 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
  10. Mar 16, 2011 at 1:01 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    so which fuse should I check for my heater fan/blower motor?:confused:
  11. Mar 16, 2011 at 6:06 PM
    kbp68
    B.C.
    TRD Off Road DC/SB
    The 50amp looks good - how do you check a relay (other than just replace it?):confused:
  12. Mar 16, 2011 at 6:09 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    or is the 50 amp a block heater?
