AC/Heater Control Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by elvis82, Apr 3, 2013.
  1. Apr 3, 2013 at 5:51 AM
    elvis82
    elvis82 [OP] Member
    Tennessee
    03 X-cab V6
    All of the controls for my AC/Heat work fine except for the directional control. When I turn it nothing happens and air only seems to blow out of the defrost, floor, and outer vents but none through the center. It's like it is stuck and it just randomly started happening. Is there a specific fuse for the directional control knob or is this something else? Thanks
  2. Apr 3, 2013 at 6:10 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Is the knob broken? Can you hear it cycle through the different vents when you turn the knob?
  3. Apr 3, 2013 at 1:38 PM
    elvis82
    elvis82 [OP] Member
    Tennessee
    03 X-cab V6
    No, the knob seems to be working fine and is cycling through. I removed the knob and made sure it wasn't stripped.
  4. Apr 3, 2013 at 11:18 PM
    elvis82
    elvis82 [OP] Member
    Tennessee
    03 X-cab V6
    Edit: The knob isn't cycling through vents when turned. It is not stripped though and clicks when turned.
  5. Apr 4, 2013 at 6:03 AM
    Madjik_Man
    Colorado Front Range
    There's a mode control cable behind there. Make sure it's connected and operating properly.
    See if the attached helps.
    EDIT: I see you're in an 01-04... the attached is for a 95-00
  6. Apr 5, 2013 at 10:00 AM
    elvis82
    elvis82 [OP] Member
    Tennessee
    03 X-cab V6
    Yeah, if I'm not mistaken I think the 01-04's are controlled electronically vs a cable.
  7. Apr 5, 2013 at 10:45 AM
    Madjik_Man
    Well if you want, here's the 01-04 f ac to ry se rv ice ma nu al.
    I tried looking it up for you but the categories are abbreviated and, no offense, I didn't want to spend time deciphering it all.
    But you can :eek:
    http://www.mediafire.com/download.php?tne782on1mre9mj
  8. Apr 6, 2013 at 6:37 AM
    elvis82
    elvis82 [OP] Member
    Tennessee
    03 X-cab V6
