AC/Heater Fan Only Works On High...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drew12, Jul 10, 2017.
  1. Jul 10, 2017 at 6:38 AM
    Drew12
    Drew12 [OP] Well-Known Member
    Andrew
    Sisters, Oregon
    2005 4x4 TRD OR Access Cab
    Bilstein 5100's/Toytec 620 coils, rear AAL, Camburg UCA's, Pro Comp 7069, AFE stage 2 CAI, Blacked Depo Headlights
    Whats up guys,
    Every few months my ac/heater fan only works on high, then just as quick as it came, it returns to normal working order. Has anyone experienced this before with their truck? Or does anyone know what the cause of this may be? Its back to normal now but I have a feeling that it will return which is not fun because its been pretty dam hot here in central Oregon. If anyone can help thatll be much appreciated.
  2. Jul 10, 2017 at 6:55 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jul 10, 2017 at 7:32 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Resistor
  4. Jul 10, 2017 at 7:34 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
  5. Jul 10, 2017 at 10:04 PM
    Drew12
    Andrew
    Sisters, Oregon
    Thanks guys! Appreciate it. After further research I think I am going to buy a new resistor and connector harness. For the new wiring can butt connectors that i used for my stereo wiring be used on this application? I dont have a soldering iron but i have left over butt connectors. Good or bad idea??
  6. Jul 10, 2017 at 10:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Butt connectors are fine as long as you have the proper crimping tool and get the crimp as tight as you can.
    Use the insulated butt splices and use the crimp jaws made for insulated splices.
    https://www.youtube.com/watch?v=_buqZYHUhVo
  7. Jul 10, 2017 at 10:58 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I replaced just the resistor, plug and play, no problem, takes 2 minutes
  8. Jul 10, 2017 at 11:02 PM
    Drew12
    Andrew
    Sisters, Oregon
    I have the red connectors which are for 18-22gauge wire. Is the part number
    82141-04M40 within this gauge?
  9. Jul 10, 2017 at 11:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm not sure what the gauge the pigtail harness wire is... I am pretty sure it is larger than 18 gauge.
  10. Jul 10, 2017 at 11:17 PM
    Drew12
    Andrew
    Sisters, Oregon
  11. Sep 4, 2018 at 12:05 PM
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
