AC/Heater fan stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkrdave36, Jun 24, 2013.
  1. Jun 24, 2013 at 6:51 PM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    I'm sure this has been covered in a previous post that I can't find....
    I know my AC is working because at freeway speed I can feel the cold air coming through the vents. The problem is the blower fan stopped working.
    Is there a fuse I should check, or is it the switch on the dash, or could it be the blower and or motor itself? How do I go about checking? I saw a post about a resistor but that seemed to be only when your fan worked on High. Mine is not blowing at any speed.
    Need to know ASAP. It was 105 today and will be upwards of 115 by Saturday.
    Thanks in advance!
    Beauxdon likes this.
  2. Jun 24, 2013 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Do you have the owners manual? it should give fuse location.
  3. Jun 24, 2013 at 8:46 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    hit the blower motor....
    caliburrito likes this.
  4. Jun 24, 2013 at 8:50 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Cabin filter is clean, nothing blocking air flow.
    I pulled the resistor and it looked ok.
    The connector to the blower motor looks a little "crispy" at one of the connectors.... but I have power (about 12.5vdc) at the connector on the blower side of the connector.
    The brushes,etc look ok (not burned or dirty) in the blower motor.
    I could not check the relay as I do not know what it looks like nor could I find it. Unless its under the hood?
  5. Jun 24, 2013 at 8:52 PM
    blakes09
    Blake
    Deep South
    4x4
    you have power and ground at the motor?
  6. Jun 24, 2013 at 9:49 PM
    bkrdave36
    Dave
    Wittmann,AZ
    I used my multitester and stuck one lead in one side of the plug and the other lead into the other side of the plug and got a reading of about 12.5 vdc. Not sure where a "ground" for the motor would be as no other wires were present.
  7. Jun 25, 2013 at 8:44 AM
    Irchr
    Irchr Active Member
    05 Prerunner
    Yes the same thing happened to me. I had tons of acorns inside the fan. I had to vaccum them out, but every once in a while something disloges and I get some trash floating around. IT was a mess and I too blocked the opening, but it sure was a mess. for a while.
  8. Jun 25, 2013 at 8:49 AM
    Irchr
    Irchr Active Member
    05 Prerunner
    One contact on the connector is defective and looks like it got too hot. The worst part is that you can't just replace any part of it, they want to replace the whole harness. I went to junk yard, and cut the connector off the wreck. Then I spliced it back into my harness and it works just fine now. ALl this over one socket. I see there are too many problems with the fan, I hope they fix it by the new 2014 model. I am anxious to get a new Tacoma, I have almost 200,000 miles on mine now.
  9. Jun 25, 2013 at 10:01 PM
    bkrdave36
    Dave
    Wittmann,AZ
    I hooked my blower motor straight up to the battery and it works fine, so its not the blower motor. I have a relay coming in tomorrow. At that time I will also check the ground connection and the fuse.
    I may have to do what Irchr did above with the connector as mine is looking a bit questionable on one side as well.
  10. Jun 26, 2013 at 9:22 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Well guys .... if this problem happens to you... before shelling out any cash .... go to the junk yard!
    I took this fix ...
    ... and the problem is solved! Thank god the A/C is blowing cold air again! Because the forecast for tomorrow and beyond is ...
    The moral to this sad story with the incredibly happy ending is as follows....
    Always start with the simple crap.
    I love cold air coming out of my vents!
    wilcam47 likes this.
  11. Oct 25, 2018 at 3:28 PM
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Waking this one from the dead. One cold morning blower wouldn't go I hit the dash the blower started blowing. It's been intermittent I'll have to check the harness this weekend. Only problem is with the colder I need the defroster working. I hope it's a simple as a report for replacement harness socket. I'm sure the motor is fine I don't even know where the resistor is located. You got to do some research.
  12. Oct 25, 2018 at 4:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The brushes are probably going bad in the motor, either worn down to nothing or need to be cleaned.
    Take it out and take it apart, see what you find. Also, yes, as stated many times, check the electrical connectors at the resistor and motor for burning/melting
    Tnronin[QUOTED] likes this.
  13. Oct 25, 2018 at 4:15 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I just slam my glove box door a couple of times
    tacoloco59 likes this.
  14. Oct 25, 2018 at 4:50 PM
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Tried that a bunch. No joy.
  15. Oct 25, 2018 at 5:32 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Slam it harder
    caliburrito, Tnronin and TireFire like this.
  16. Oct 27, 2018 at 10:15 AM
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Yep it's the motor. Going to take it ito this weekend I guess. Are the brushes replaceable? I replace the brushes a million years ago in my Subaru starter. LOL
  17. May 8, 2020 at 6:29 AM
    Beauxdon
    Beauxdon TTC #289
    Houston, Tx
    2010 TRD Sport DCSB
    I'm Waking this thread up. I had this issue this morning. I punched my dash on the passenger side as hard as I could and it started working. Does that mean it's the harness connection?
  18. May 8, 2020 at 6:35 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Mine does it once or twice every five years. Not in the last year or so
  19. May 8, 2020 at 6:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    No, it means you abused your truck for at best a temp fix.
    It's not that hard to do an actual diagnosis.
    Remember the last time you changed the cabin air filter? You were almost there.
  20. May 8, 2020 at 7:20 AM
    Beauxdon
    Beauxdon TTC #289
    Houston, Tx
    2010 TRD Sport DCSB
    Lol I know I know. Gonna take it out this afternoon to check for everything I have seen in the threads. Sorry Bill.
