AC/Heater keeps going in n out. Motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xguntherc, Dec 16, 2016.
  1. Dec 16, 2016 at 4:17 PM
    xguntherc
    xguntherc [OP] Taco Time
    Cory
    Vegas
    11 TRD Off Road - Black - More mods coming
    Ok looking for advice. This summer I thought my AC blower motor was going out but turns out just a couple of knocks with my fist and it starts again. I replace the resistor after reading it in a thread here and it's been fine for 5 months.. so don't think a wire is loose.
    Now it's getting cold and my fan stopped blowing again today. No heat. Tap the motor assembly and it fired back up. It's also making a clicking noise on low speeds.. could be a leaf or something, or could be the motor is going bad.
    Any tips, advice, trouble shooting would be welcomed. Thanks
  2. Dec 17, 2016 at 6:02 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the power connectors at the motor. Are they burned? It sounds like you need to replace the connector.
  3. Dec 17, 2016 at 11:19 AM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    if the resistor was recently changed then do what jimmyh said, check connectors, you can find new ones online for pretty cheap. wont fix the clicking noise tho, the clicking is a known issue as I found out recently haha ended up replacing the blower motor, new part # for motor is 87103-04044. very easy to replace.
  4. Dec 17, 2016 at 11:36 AM
    xguntherc
    Cory
    Vegas
    Yeah I don't know what I nudged down there, but it turned back on. Could be connectors, which in turn is killing motor or not giving enough power.
    The clicking has been happening for a long time. Have a link, or should I just google the part #.. I do want a new motor as that noise drives me nuts.
    Also I found one that's one number off from yes. Listed as OE. For only $41, not $100. What ya think?
    http://www.carparts.com/details/Toy...eKQ-abIIIMOuV5FsjII11BoCpq7w_wcB&gclsrc=aw.ds
  5. Dec 17, 2016 at 11:39 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
  6. Dec 17, 2016 at 11:43 AM
    xguntherc
    Cory
    Vegas
    My link above is -04043.. not 44. But listed as right and only $41. Or is that a no go?
  7. Dec 17, 2016 at 11:45 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Thank god my truck doesn't have an "air conditioning motor". Sounds complicated?
  8. Dec 17, 2016 at 11:46 AM
    xguntherc
    Cory
    Vegas
    You know what I meant... Smart ass. If you have nothing helpful to say why even post
    Sigh. Lol.
  9. Dec 17, 2016 at 11:48 AM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Would this issue cause one of the pins on the white AC control panel to show burn marks?
  10. Dec 17, 2016 at 11:50 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    it says it replaces the -04043, it will fit and work but I'm not sure who manufactures that one, I do not believe it is a genuine OEM part is all. I prefer sticking to genuine Toyota parts but that's just me.
    xguntherc [OP] likes this.
  11. Dec 17, 2016 at 11:50 AM
    xguntherc
    Cory
    Vegas
    Also.. for anyone else reading this. Model -04043 is the original part. 04044 is the upgraded blower motor for 2014-15 and WILL work. The 04044 also doesn't have the same clicking squeeking noise.
    So yeah. Looks like I need to get the newer one. Thanks guys
  12. Dec 17, 2016 at 11:54 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    that is correct, but not just for the 2014-15, it fit in my 09. I was trying to find the thread I read that had all that helpful info in it haha the newer generation is also like the 3rd or 4th generation so hopefully they finally figured out the issue
    and I believe this is the connector
    https://www.amazon.com/Genuine-Toyo...F8&qid=1482003698&sr=1-1&keywords=82141-04m40
  13. Dec 17, 2016 at 11:57 AM
    xguntherc
    Cory
    Vegas
    Yup it fits and is the official replacement for all 05+
    Looks like I'll be getting the newer one and getting rid of those clicky noises. Finally. Thanks man, for actually being helpful.
    Do I need the connector too? Probably should since I think mine might have a short of some kind.
  14. Dec 17, 2016 at 11:59 AM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    glad I could help.
    p.s that connector I'm not 100% sure that's the correct one haha I'm doing a little digging atm
  15. Dec 17, 2016 at 12:06 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    the connector I linked is not the connector that plugs into the motor itself, its the climate control connector. still trying to find the motor connector. if any of the pins on your connectors look burnt then yeah I would replace them.
  16. Dec 17, 2016 at 12:09 PM
    xguntherc
    Cory
    Vegas
    I'll pull it out and check. Thanks bro
  17. Dec 17, 2016 at 12:17 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    Found this on another thread. Looks like the motor connector. Good luck! enjoy the click free motor haha
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
  18. Dec 17, 2016 at 12:41 PM
    xguntherc
    Cory
    Vegas
    From what I can see the connectors look fine. No burn marks. I checked the resistor connector when I replaced it, and was fine. I'll check it again shortly. Looks like I just need a new blower. Good thing I just got a $250 Amazon gift card. ;-)
    Bocsy44 likes this.
  19. Dec 17, 2016 at 1:41 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    loose connection usually, increased resistance, more heat = burn marks
  20. Dec 17, 2016 at 1:47 PM
    THE CALICO
    Colton
    Nashville
    So maybe it's just not seated inside the connector?
