AC/HEATER NOT WORKING
Discussion in 'Technical Chat' started by qbnpapi, Oct 18, 2011.
  1. Oct 18, 2011 at 4:39 PM
    qbnpapi
    qbnpapi [OP] Member
    Papi
    FELLOW TACO LOVERS!!!
    Looking for a little guidance. My a/c has stopped working. Recirculation button still lights up but not the a/c. The fan is not working in any speed. I have checked the fuses both IG1 AND IG2 10A fuses as well as the 10A fuse in the engine compartment. All are still good. I read something about the HVAC resistor going bad, but what i have read is that it works for some in some speeds. I have NO speeds. Does any one know the value of the resistor to check it, so I can rule that out before I spend the $ on it? ANy help would be much appreciated.
  2. Oct 18, 2011 at 4:42 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    what year is your truck?
  3. Oct 21, 2011 at 12:12 PM
    qbnpapi
    qbnpapi [OP] Member
    Papi
    2006 off road trd 4x4
  4. Oct 22, 2011 at 12:56 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Go to the connector at the blower motor, pull it out. Take a test lamp, and jump it from one side to the other with a test lamp in line. If it dosent light up, time to trace some other way. If it does, time for a new blower motor my friend.
    AlaskanTaco
