AC idler bearing 5vz P/N
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, May 14, 2018.
  1. May 14, 2018 at 9:05 PM
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
  2. May 14, 2018 at 9:13 PM
    License2Ill
    Ian
    BTW I'm being overly dramatic. :)
  3. May 14, 2018 at 9:15 PM
    License2Ill
    Ian
  4. May 14, 2018 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yeah, that looks like the one Dan used. There several available. There all the same dimensions, tho I'm sure there is a quality difference.
    Here is the one I ordered: https://www.amazon.com/dp/B010OLLHM...olid=1P5D39KHH5V3M&psc=0&ref_=lv_ov_lig_dp_it
    FWIW, I ran quite a ways with mine noisy AF. I was too hot to touch when we finally did the swap with the pulley from O'Rielly's but it never caught on fire or froze up or made the belt jump off.
    We had a skunk take a liking to Monte's truck bed one evening in camp. Little fucker would not leave. They finally gave up trying to shoosh it away and went to bed in the RTT directly above where the little guy was hanging out. He was gone in the morning. YMMV
    License2Ill[OP] likes this.
  5. May 14, 2018 at 9:47 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  6. May 14, 2018 at 9:50 PM
    License2Ill
    Ian
    Thanks man!
    Yeah I could always pull the belt. But it'd be nice to have an order in and a delivery outgoing before I leave pavement.
    This little guy is at my feet everytime I sit down. Probably being fed.
    Thanks again Mike!
    Digiratus likes this.
  7. May 14, 2018 at 10:00 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yep, you can order that one Mike mentioned, or the one I got, which is the first one you linked. I've since had mine pressed into the OEM pulley and it worked great.
  8. May 15, 2018 at 12:12 AM
    License2Ill
    Ian
    mechanicjon[QUOTED] likes this.
  9. May 15, 2018 at 12:18 AM
    License2Ill
    Ian
    How much effort does it take to press in? I was under the impression a c-clip was used to secure it, no?
  10. May 15, 2018 at 12:21 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    C-lips secures it. It doesn't much to knock them out. Just a socket that will catch the outer race and a hammer.
  11. May 17, 2018 at 11:51 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You might try loosening the tension a little for less stress on the bearing.
  12. May 18, 2018 at 7:41 AM
    WVTaco12
    WVTaco12 Well-Known Member
    Cody
    West Virginia
    2013 TX Baja
    I purchased the whole AC idler pulley for under $40. ac idler pulley 88440-04040 - there’s the OEM part number. Gunny can get you a good deal on one. Let me know if you need more info. Good luck!
  13. May 18, 2018 at 6:35 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I heated up the pulley to where it was uncomfortable to touch bare handed, and put the bearing in the freezer. Dropped right in.
  14. May 18, 2018 at 11:03 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Question, are you guys getting a loud howl noise from the AC compressed when it's on? Is the new bearing supposed to fix it or is my AC compressor going to take a dump? I can tell the howl is much louder when the compressor kicks on.
  15. May 19, 2018 at 12:27 AM
    License2Ill
    Ian
    Idler pulley is always turning with the engine.
  16. May 19, 2018 at 8:28 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I see. So it's safe to say it's my compressor
  17. May 19, 2018 at 9:22 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Just went through this two weeks ago. My compressor was in the process of taking a dump. After the replacement the idler pulley (bearing) really shit the bed. Bearing cage came out in chunks. I had the part number for an NGK bearing but the dealer had a whole pulley available that day. I was in a pinch so I bought the whole assembly. As for bearing replacement it’s super easy with no press or heating. Just do it carefully with a socket.
    It’s an NSK bearing 12mm shaft dia 12mm thickness and 37 mm OD.
    Edit: it’s an NSK 63012RS-DDU bearing
  18. May 19, 2018 at 11:22 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So you replaced your AC compressor but not the pulley? I'm currently in the opposite situation.. been pulley but the compressor is still really loud
  19. May 19, 2018 at 11:28 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Compressor was replaced, then the pulley seized and belt snapped. Replaced entire pulley. Now all is well.
