AC in 2012 Tacoma is acting odd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfayne, Sep 17, 2020.
  1. Sep 17, 2020 at 3:39 PM
    cfayne
    cfayne [OP] Well-Known Member
    Santa Clarita
    2012 Tacoma V6 six speed FUN
    Pro Comp wheels General Grabber AT tires
    Hello All,
    Well, with the heat wave in Southern CA almost over, our AC is now acting up. The VERY weird thing about this is we get cold air from the two outside vents, the ones by the window. The two inner vents, by the stereo, is blowing out WARM/HOT air!
    The only thing I can think of is a servo to a flap on the airbox under the dash might be off, but this is just too odd for me to wrap my head around. Has anyone else had this problem? Is there an easy solution?
  2. Sep 17, 2020 at 7:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a low R134a Charge issue and a leak. I had a leak and the symptoms were Drivers side vent cold, and as you move towards the right the air discharged was warmer as you proceed to the passenger side vent.
    Cold >>> Cool >>> Warm >>> Very Warm.
    Repaired the leaks and recharged and has been good for several years now.
    There have been several on here with the same symptoms and all have ended up being a leak.
    Don't use a auto parts store R134a Cans to charge it. It's just going to leak out again.
  3. Sep 18, 2020 at 4:20 PM
    cfayne
    Santa Clarita
    Thanks Jimmy. I would not have thought about low refrigerant, but that turned out to be the problem. We are giving it some time before we recheck it to see if it leaked, but all looks good now.
    Thanks.
    Steves104x4 likes this.
  4. Sep 18, 2020 at 4:28 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :thumbsup:
    Did you find the leak and get it repaired?
  5. Sep 18, 2020 at 4:39 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I started having this issue about 2 weeks ago but like stated above from left (driver cold) to right (passenger warm) but i haven't tried to diagnose yet but hopefully level is just low and a small leak somewhere easily fixed.
    This thread was just going recently,maybe will give you a bit more info
    https://www.tacomaworld.com/threads/2012-ac-troubleshooting-steps.684703/
  6. Sep 18, 2020 at 4:44 PM
    cfayne
    Santa Clarita
    We have not found a leak. We are going to recheck it in a week or so as we were not looking any pressure when we filled it up, but we shall see.
