AC In snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDBandit, Nov 18, 2010.
  1. Nov 18, 2010 at 10:13 AM
    TRDBandit
    TRDBandit [OP] TACOMANATOR
    Justin
    CRAWLORADO
    07 Dbl Cab TRD O.R. Dark Blue
    Afe Stage 2 CAI Tinted windows Many to come
    How do they do as compared to a DC.
    any difference since the DC has more added weight to the rear
  2. Nov 18, 2010 at 10:17 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Not well, it's very light in the rear.
    I put cables on and it was 200 times better, but this was only for a couple inches of snow on the road.
    I'm guessing you have a 2x4 like me. If you have a 4x4, you should be just fine. If not you can put some weight in the back.
  3. Nov 18, 2010 at 10:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have an AC and it's been great in the snow - obviously, I have 4WD and the mechanical LSD. I really don't think there's any difference between the two that you'd ever notice.
    The only complaint I have with mine, is my stock tires w/ 30k miles on them. They're starting to feel weak. That's the tires...not the truck. I will probably put some weight in the back to compensate for the tires.
  4. Nov 18, 2010 at 10:21 AM
    TRDBandit
    Justin
    CRAWLORADO
    Im Talking even with 4x4 and the rear locking diff.
    I am in the market for a new one.
    Its a choice between a White DC one with 84,000 wich the milage is what scares me
    or a black AC with 54,000 miles
    both trd OR
  5. Nov 18, 2010 at 10:24 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    you dont wanna use a locker in the snow...that will only make your ass end slide out even worse. 4 hi and your good to go, throw a few 50lb bags of sand in the bed if your worried about it.
  6. Nov 18, 2010 at 10:26 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Well I have an '05 with 90k on it and I will tell you that it runs like brand new... The winters here were a learning experience for me with this truck. I am thoroughly convinced that the 1st gens are better in the snow than the 2nd gens. I think the back end is just really light and this truck has more power. You just gotta be light on the gas. In 4wd though, my truck is very sure footed. The rugged fails I am rolling really gotta go though
  7. Nov 18, 2010 at 10:32 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I don't there's much of a difference on roads between the DC and AC. The long bed would be more stable since it's got a longer wheel base. Both the AC and DC have light rear ends but good tires, a little weight and a light foot and they'll go through anything. I'd get the truck that better fits the rest of your needs.
  8. Nov 18, 2010 at 10:37 AM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    lol throw a new tbelt and water pump on the white one soon and youll be good to go .... its a toyota for christ sakes i cant believe someones scared of 84k miles
    but if you dont need the room of the double cab personally id go for the access cab because from what i understand the bed is bigger.
  9. Nov 18, 2010 at 10:46 AM
    Janster
    Jandy
    Lancaster, PA
    The wheel base for an AC (standard bed) and the DC (short bed) are the same.
    If you get a DC Longbed (standard bed) - that has a longer wheelbase.
  10. Nov 18, 2010 at 10:51 AM
    Di Trut
    Di Trut Well-Known Member
    since the DC will be slightly heavier it will get a bit better traction on slippery stuff. But i really don't think you will notice the difference much, if any.
    Your decision of AC vs. DC should be based on which configuration better fits your lifestyle.
  11. Nov 18, 2010 at 11:10 AM
    97T
    Melt
    Littleton, CO
    lmao thats hilarious
    do they still offer the 7' bed on single cab tacos?
  12. Nov 18, 2010 at 11:55 AM
    Janster
    Jandy
    Lancaster, PA
    6' bed is the longest you can get.
    They never made a 7' bed.
  13. Nov 18, 2010 at 12:22 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    They are chains not belts. Go A/C unless you need the cab space so you have the advantage of the larger bed.
  14. Nov 18, 2010 at 12:28 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    never had a problem in my AC in light/heavy snow conditions...i do live in las vegas but every weekend during the winter months I'm heading to a ski resort whether its mammoth, tahoe, colorado, utah...you name a state on the west coast I've driven to it...that was all on OEM Rugged Terrain tires in 2 wheel drive...very seldom did I ever find myself putting 4x4 on...but that's when the roads were completely iced over, 1' plus of fresh snow on the roads, and steep grades up and down the mountain...
    I do have a water bladder that I can fill up to add weight over the rear end but never found the need to fill it up since 4x4 and rear locker does the trick...:thumbsup:
  15. Nov 18, 2010 at 12:29 PM
    97T
    Melt
    Littleton, CO
    my bad i guess the tacoma never had one, coulda sworn my friends 92 had a 7' bed
  16. Nov 18, 2010 at 12:36 PM
    Rodallg
    Rodallg Well-Known Member
    CA
    What tires do you have on the truck?
  17. Nov 18, 2010 at 12:52 PM
    97T
    Melt
    Littleton, CO
    he said OE so either dunlop or bfg rugged trails
  18. Nov 18, 2010 at 1:41 PM
    97T
    Melt
    Littleton, CO
    dammit thats the second time ive been wrong today lol
  19. Nov 18, 2010 at 2:14 PM
    The Wombat
    The Wombat Active Member
    Mass.
    09 Access Cab 4WD 4-cyl
    none
    I've got a 2009 AC, manual tranny, and I live in New England. Truck is stock everything with ~30k on it.
    I just throw a few bags of tube sand in the back, it settles down real fine. I could get along without the sand just fine, it's more of a driving style adjustment than any problems with the truck. If I calmed down, it'd be fine - but what's the fun in that?
  20. Nov 18, 2010 at 2:16 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I use my AC X-Runner in snow, Works great :D
