AC is stuck ON.. what to do..?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TIPICOTACO, Aug 8, 2011.
  1. Aug 8, 2011 at 8:45 PM
    TIPICOTACO
    TIPICOTACO [OP] Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    So I replaced the stock CD player in my '01 DC TRD w/ a new HU on Sunday.. Everything went as expected, but today I noticed that my AC seems to be stuck ON.
    The button still functions like it should, light works on and off etc.. as does everything else on the controll panel, but whether it is pressed in or not the AC is def still engaged..(water still dripping from front pass side & vents blow cold as hell)
    I removed the temp control face plate again and tinkered with the button but I can't seem to figure it out :confused:
    Anyone ever experienced anything like this??!?? should I just pull the AC fuse and run the vents w/o it? Im drawing a huge blank here.. please help!!
  2. Aug 8, 2011 at 8:47 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Take the fuse out?
  3. Aug 8, 2011 at 8:48 PM
    BlueTaco07
    Cody
    Looking
    If you pull the fuse put it back in and its still stuck you effed up wiring to it somewhere along the line
  4. Aug 8, 2011 at 8:48 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Since it happened after your head unit install I'm gonna guess you either pinched a wire or something got wired up incorrectly during the install. Maybe try removing the hu and see if you can see anything like that.
  5. Aug 9, 2011 at 6:30 AM
    TIPICOTACO
    Tyler
    nw nj
    thanks for the responses..
    I didn't have to wire anything because the HU came out of my '97 Taco and already had the wiring harness attatched.
    I'll remove and replace the fuse first and if that don't work I'l pull the dash apart again and look for a pinched wire..
  6. Aug 11, 2011 at 8:50 AM
    TIPICOTACO
    Tyler
    nw nj
    well I couldn't find where the AC fuse is :(
    BUT... I disconected the plug under my drivers seat to get rid of the flashing seat belt indicator, and not only did this also get rid of the "you left your lights on moron" sound , but the AC is now back to normal.:confused:
    I don't think these are even related but it worked and I'm happy. weird
  7. Aug 11, 2011 at 8:56 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Sounds like a good problem to have. Imagine the opposite.
  8. Aug 11, 2011 at 9:57 AM
    TIPICOTACO
    Tyler
    nw nj
    the opposite would suck, but this is my first vehicle that actually has a working AC so I would get over it.
    my main concern was in the winter what would I do. I always thought that turning the heat up while the AC is on is very bad thing.
  9. Aug 11, 2011 at 10:07 AM
    macgyver
    Brad
    Canton, GA
    Nope not at all, it's actually better to run it to keep the AC system lubricated. I run my AC all winter. It keeps the windows from fogging up and the air dry and not musty. The heat is just as hot with the AC on vs. off IMO. In fact, I rarely have to use my defrost in the winter. The only time my AC is off is if I have the windows down and the air completely off.
  10. Aug 11, 2011 at 10:17 AM
    jeckel7234
    jeckel7234 Well-Known Member
    Drew
    VA
    05 Tacoma
    Add-a-Leaf, Leveling Kit, 31.5 Nitto Grapplers, Mag-Lite Mod, Anit-Key in the ignition beep mod, Tail gate theft mod, Trifecta tonneau cover, washable cabin air filter,
  11. Aug 11, 2011 at 10:22 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Tacoma ECUs are programmed to engage the compressor clutch occasionally regardless of the AC being on or not.
  12. Aug 11, 2011 at 10:24 AM
    IronCladTRD
    IronCladTRD Consistently Irregular
    Corbin
    Hotel California
    2003 4x4 Manual V6 3.4L
    5100s/Eibach 3" lift, All-Pro Expo rear leafs, Elite front bumper & sliders, Smittybilt XRC8 winch, 33x10.5r15 BFG All terrains, Ultra Rogue 15x8 rims, homemade bed rack, Midland 1001z CB radio Deckplate mod, Century shell, train horn, debadged
    Buy a nice warm sweater?
  13. Aug 11, 2011 at 10:41 AM
    TIPICOTACO
    Tyler
    nw nj
    great info, thanks :)
  14. Aug 12, 2011 at 7:49 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    If you have the either of the defrost modes selected, the A/C will engauge. Reguardless of the button position
  15. Aug 12, 2011 at 7:51 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Move to Arizona?
