AC Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nswan, Jul 15, 2024.
  1. Jul 15, 2024 at 12:28 PM
    Nswan
    Nswan [OP] New Member
    Nathan
    About a week or so ago my ac shut itself off while driving. At the time when I would try to turn it back on, it would have a faint whistling noise, then shut itself off again after about 5 seconds and it wouldn’t blow any cold air. I didn’t know what the problem was so I figured maybe it was low on refrigerant so I bought a can along with a pressure gauge. The low end of my pressure reads in a range of 90-120psi, so the gauge might be wrong. Regardless something is pretty messed up. Then when I just tried to turn the ac on again, it makes a very loud noise almost like a belt rubbing. I don’t want to keep turning it on to listen because I don’t know what the problem is. Does anybody here know?
  2. Jul 15, 2024 at 12:37 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Are you familiar with where the AC compressor is located in the engine bay? If so, take a peak and see if you notice anything funky with the pulley/ drive belt. If you are hearing not normal mechanical sounds, it is most likely something mechanical! Good luck.
    NoOne likes this.
  3. Jul 15, 2024 at 12:57 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Could be issues with the A/C compressor OR the magnetic clutch on the compressor.
    NoOne likes this.
  4. Jul 16, 2024 at 5:37 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Don't just top off with can O joy from the auto parts store, get it to a good AC tech. If it is low, where did it go? You have a leak.
    t0p_d0g likes this.
  5. Jul 16, 2024 at 6:23 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Hopefully, you used the right ac, 1234YF. Never just add refrigerant to a system without pressure gauges at a bare minimum. There is a pretty tight refrigearant weight specification that needs to be adhered to for the system to function properly. 90-120# on the low side with the compressor engaged? If so, you are overcharged. I can only imagine what the high side pressure is. The noise you hear now is the belt slipping as it is trying to engage the clutch and and is slipping on the pulley. You are potentially ruining any of the components in the ac system. I would not turn the AC or defrost on until you have the system professionally looked at
    usmc2msu likes this.
  6. Jul 17, 2024 at 5:17 PM
    JimmyoNY
    JimmyoNY Active Member
    Jim
    2019 Tacoma
    Interesting... This just happened to my 2019. My A/C magnetic clutch is failing and it will slip for a bit and make a noise and then disengage. The compressor itself spins freely with the belt removed. The weird part is that I couldn't find a Toyota replacement clutch anywhere. They all say "out of stock" and one parts dept told me it was discontinued. I ordered an aftermarket kit, but I wonder why Toyota doesn't have this part in stock. Is it a common problem?
  7. Jul 19, 2024 at 6:08 PM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Check your clutch, they are commonly failing, and can make noise when they fail. parts stores do not sell the clutch without the compressor too, but Ebay will sell the clutch alone for $50 and it takes 10 minutes to install, only a small wrench, no need to deal with freon, and do not even remove the belt. I have explained how to test and replace the clutch in a couple other related threads, and at least one member replaced his and reported that it was easy.
    Consider searching for my other posts, in the past couple months, for details. Why throw out a whole compressor, and deal with freon when (if it is a bad clutch) it can be so easily fixed? Did mone years ago, and the repair held for many years.
    BTW, I have never hears of any garage mechanic willing to replace only the clutch, so check it out and save $1,000 to $2,500, but fixing yourself.
    Good luck!
    CrashZone, Brikan and JimmyoNY like this.
  8. Aug 9, 2024 at 6:00 PM
    JimmyoNY
    Jim
    2019 Tacoma
    This is exactly what I ended up doing. The failure point was the outer clutch plate. It has a rubber damper which failed. It sure beat changing the compressor, condenser, etc.
    CrashZone likes this.
  9. Aug 10, 2024 at 6:10 PM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    Yeah same deal here, shame I went through all the trouble of buying bunch of snap ring pliers, zipped the 8mm bolt off the outer cover/clutch, watched it fall to the ground in two pieces. Didn't bother going further and just zipped on the new AC cover after turning the compressor by hand to check that, reused the original spacer and now the AC works. Now if only the ADD was just as easy to take off, or the inner driver CV cup that took five hours to get off, even with a 10lbs slide hammer.
    JimmyoNY and CrashZone like this.
