AC Issues
Discussion in 'Technical Chat' started by jscott1013, May 6, 2018.
  1. May 6, 2018 at 3:15 PM
    jscott1013
    jscott1013 [OP] New Member
    Jeremy
    2013 Tacoma Pre Runer
    I tried using the search function to answer this question and could not find anything so please bear with me. I have a 2013 Tacoma Pre Runner with the 4.0 engine. About 8 months ago my A/C would only work on high, so I replaced the blower motor resistor and it worked! Started to have the same issue so I went to replace the part again.
    My new resistor came with a new plug. So I replaced the resistor and the plug, along with adding about 3 inches of wiring with the new plug. The wiring is connected and I know I have a solid connection. When I drove to work A/C or heat did not work at all, even on high. On the way home A/C worked as it should on all settings!!! Now it's not working again :(. Any Ideas???
  2. May 6, 2018 at 4:18 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I’m just guessing but since it’s intermittent possibly a short or loose connection. But finding it will be a challenge if is is that.
