AC knocking when on max
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pscott, Jun 21, 2021.
  1. Jun 21, 2021 at 8:57 AM
    pscott
    pscott [OP] Member
    2006 Tacoma trd
    TIA. My 06 Tacoma TRD makes a knocking sound when the Max ac button is pushed. Blower motor and filter removed, cleaned and seem fine. I keep on top of those. Below the glove box, and above the cabin filter seems to be where the knocking sound is coming from. Any suggestions?
    Black DOG Lila likes this.
  2. Jun 21, 2021 at 9:07 AM
    pscott
    pscott [OP] Member
    2006 Tacoma trd
    So when the max ac button is pushed these two flaps come down, to close off the outside air I assume. They seems to be clapping against this plastic piece(stationary) and are definitely creating the slapping/knocking sound. If that helps. Any tips to fix that?
  3. Jun 21, 2021 at 9:09 AM
    pscott
    pscott [OP] Member
    2006 Tacoma trd
    Doing more research and it seems these are called the blend doors and I’m assuming it’s the blend door motor. Easy to replace?
  4. Jun 21, 2021 at 9:13 AM
    pscott
    pscott [OP] Member
    2006 Tacoma trd
  5. Jun 21, 2021 at 10:09 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Most likely the servo motor for the recirculation door has failed and the gears are stripping causing the noise.
    Jimmyh and TnShooter like this.
  6. Jun 21, 2021 at 1:08 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    It's called Blend door actuator if that helps any.
  7. Jun 21, 2021 at 1:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
