AC Leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cowie, Jun 14, 2021.
  1. Jun 14, 2021 at 12:41 PM
    Cowie
    Cowie [OP] New Member
    Andrew
    2017 TRD Sport
    So I just started using my AC this summer about a few weeks ago( I live in Canada ) and noticed the air was g very cold . The vent on the far left is coldest, further right you go it gets warmer.
    Took it in to the dealer and they said I have a leak in one of the lines. My truck is a 2017 Sport with only 31k KMS. My warranty ran out about 6-7 months ago and then want 800$ to repair it. Has anyone had luck contacting customer service and getting repairs covered outside of warranty? The AC going on a low km truck like mine is rediculous .
  2. Jun 14, 2021 at 12:45 PM
    Tripod1404
    Tripod1404 Annihilator tripod
    Why would they cover it outside of the warranty?
    philth, RedWings44 and Skydvrr like this.
  3. Jun 14, 2021 at 12:48 PM
    Cowie
    Andrew
    2017 TRD Sport
    Because it has 31k KMS and is only 3.5 years old and the AC is going. That’s insane.
  4. Jun 14, 2021 at 12:50 PM
    Tripod1404
    So? Warranty period is 3 years or xxx kms, which ever comes first. It is not 3 years plus an arbitrary amounts of months if mileage is low.
  5. Jun 14, 2021 at 12:55 PM
    danakinskyrocker
    danakinskyrocker Well-Known Member
    21 DCSB OR Cement
    But to Tripod's point, you have no warranty that requires them to cover it. You can try, you can fight, but there's nothing binding for the dealer to give you goods and services for free here.
  6. Jun 14, 2021 at 1:10 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Did you inspect the lines? Look like an easy fix?
  7. Jun 14, 2021 at 1:15 PM
    GreenYoda
    GreenYoda Well-Known Member
    If the air is getting cold, there is probably no leak. Check the vents with a thermometer and see if they are getting cold enough. Anything under 50 should do it. For my home A/C I like to see 40 degrees. For a car I have never measured it.
    My taco AC did leak after 110k miles. It was the condenser in front of the radiator that leaked. Air was not cold at all.
  8. Jun 14, 2021 at 1:18 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    My truck gets around 34, but that's cruising on the freeway. At idle depending on ambient anywhere from 40-60
  9. Jun 14, 2021 at 1:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    Your symptoms are a classic leak indicator, early stages. It won't be long till you have no AC.
    What 'line'? Specifically the leak location. It matters on how complex (and expensive) the repair is.
    Not gonna happen. Everything has a finish line, and you've crossed it. Not only will your dealer not care, Toyota will care even less. As would any manufacturer.
    I'd take it to a quality independent shop that has all the right tools and reputation, and get it fixed there.
    Sorry for your bad luck.
