AC light blinking blowing hot air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hilham, May 15, 2018.
  1. May 15, 2018 at 3:10 PM
    hilham
    hilham [OP] Active Member
    Hilham TN
    Silver TRD Off Road DCSB
    help 2nd gen tacoma owners. My son has a 06 tacoma and the ac light blinks and blows warn air. anyone have any idea what this is?
    thank you for any help you can give
  2. May 15, 2018 at 3:21 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  3. May 15, 2018 at 8:04 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    Probably a destroyed A/C compressor clutch. There's an aftermarket replacement available on eBay for less. Check out the front of the compressor and search for a thread on here with the details about the aftermarket clutch.
  4. May 16, 2018 at 7:52 PM
    NonfunkScoop12
    NonfunkScoop12 Member
    2012 V6 DC TRD Sport PreRunner
    None...yet.
    Probably obvious, but did you check refrigerant pressure? I think if it's low, the system won't allow compressor to run, resulting in the blinking light. But a separated clutch hub, replacement is about $50 on eBay, is the usual culprit. My issue was the magnetic coil that engages the AC clutch, it also caused the blinking light.
  5. May 16, 2018 at 8:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The blinking light comes from the rotation sensor on the compressor. All it means is that the clutch was commanded to engage, but the rotation sensor did not sense proper rotation. It disengages the clutch and blinks the AC Lamp to let you know there is an issue. If the coolant pressure is low the system will never come on and the light will not blink. Or if the pressure is on the edge it may come on for a brief time then kick off, but the lamp still will not blink.
  6. May 18, 2018 at 8:43 PM
    hilham
    Hilham TN
    Thank you tacoma world everyone is so quick to help. many of you were right it was a bad compressor.
    thanks to you all for the help
