AC Light Blinking, Ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by martindo72050, Jun 26, 2022.
  1. Jun 26, 2022 at 3:44 PM
    martindo72050
    martindo72050 [OP] Member
    Martin
    2010 Tacoma SR5 V6 4x4
    AC light has been blinking for a while now, wondering if anybody has any idea what it could be. Here's everything I know about the problem
    Truck: 2010 Tacoma V6 4WD
    Ever since I bought the truck at 115k miles a year ago, I noticed the fan works at either full blast or off. Occasionally the middle fan setting will work, but its very random.
    at 150k miles, a couple weeks ago, I was idling with the AC on and as I shut off my engine I noticed some kind of knocking sound, and upon exiting the vehicle a strange smell was present that I cant describe (I forgot what it smelled like).
    The next day, I turn on the AC and after a few seconds, the light starts blinking. I looked and in those few seconds, I can clearly see the clutch engaging, then disengaging and the light turns on.
    I'm kinda new to AC systems but I cant afford to take it to a shop, any ideas on what to look at first? I've seen this write up already but I basically only have $300 to fix this issue and its hot as balls in Houston.
    https://www.tacomaworld.com/threads/a-c-light-blinking-troubleshooting-guide.440200/
  2. Jun 26, 2022 at 4:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The full blast or Off is likely the blower motor resistor,
    The flashing light is going to take an actual diagnosis, as it only flash if there is a system fault.
    If you’re on a budget, you don’t have much choice other than following the info in the link.
    I dread the day I have to “work” on mine.
    I’ll likely run with the windows down, as I find AC work intimidating.
    Dm93 and Key-Rei like this.
