AC light comes on when I turn on my heater
Discussion in '1st Gen. Tacomas (1995-2004)' started by FatalFoxCry, Oct 20, 2017.
  1. Oct 30, 2017 at 11:22 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check out the other post I quoted. From the first PDF (on the left) on the first page it looks like by 2000 they put an switch that would close when defrost was selected. I'm thinking of that one was not allowed to close when you selected defrost it would allow normal push button AC and not switch on the AC when using defrost. Whatchya think?
    And your Brony fan forum web history is our little secret - bronies 4 lyf
    :fistbump:
  2. Oct 30, 2017 at 11:31 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Also yeah, I believe that would be correct, neither switch should stop the other from functioning, they're parallel.
    Dalandser[QUOTED] likes this.
  3. Oct 31, 2017 at 12:06 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    So it looks like you can do this without hurting the AC button's function for when you'd usually want AC on. I'm assuming this means you could turn it on if you needed it when the vent setting is on defrost and when it isn't. Here's my take on a diagram:
    So if you take out the control plate with the vent control switch you should see a wire and I'm guessing you could follow it to a switch that hopefully will use a connector you could unclip and see if my theory works. If it doesn't, you can just reclip the connector to the switch. You could also try cutting the wire and taping off the ends, but just know how to solder in case it doesn't have the desired result.
  4. Oct 31, 2017 at 8:04 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The blower motor not working on the low setting is probably a bad blower motor resistor. It's a separate part from the blower motor.
    COMAtized99 likes this.
