ac light flashes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808army, Sep 10, 2012.
  1. Sep 10, 2012 at 1:17 PM
    808army
    808army [OP] Well-Known Member
    hawaii
    17 offroad
    I have 06 tacoma start notice light flashes wen in any mode when ac on. can get any more info what cause this. thanks and when flashes stops blowing cold
  2. Sep 10, 2012 at 2:32 PM
    BamaToy1997
    Bill
    Navarre, FL
    The light flashes to let you know the computer has detected a problem that is preventing the compressor from being engaged. This can range from a low charge to a short in a wire, or a bad switch/sensor. Do you have access to a scan tool?
  3. Sep 10, 2012 at 3:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you don't have a scan tool take it to autozone or ... and see if they can read the code for free.
  4. Sep 10, 2012 at 3:39 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    This happened to me last week, mine was flashing because my compressor seized.
  5. Sep 10, 2012 at 6:14 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i know this problem existed on early 1gr 4runners due to the compressor relay. search google it and see if you have the same system/ relay. not sure if the new part is improved or not
